EKOS clone and upgrade questions.
  • forescott
    Hopelessly Addicted to RC
    • 2686
    #181
    I've had both. The feigaos have more power, and they are cheaper! BUT......you need bigger esc's with the feigao xl's. The ammos will run on the stock 60-amp esc's.
    • Diesel6401
      Memento Vivere
      • 4204
      #182
      Good info buddy!
      - Diesel's Youtube
      - Diesel's Fleet
      • JPriami
        N4FOX
        • 1675
        #183
        I completely took apart my struts to find the noise I was hearing. I think it was a combination of things. One was a found a bearing thats bad. it spins but feels like there is a flat spot on the bearing when you spin it. The other part of the noise I may have been hearing was where the ball joint screws into the strut tube. both ball joints were very loose where they screw together. I'm going to loctite those together. Now Im waiting on a new set of bearings before I put it together. But I did get my wire drives today :D
        • JPriami
          N4FOX
          • 1675
          #184
          Will the feigaos 9xl's run on a 80amp esc?
          • LarrysDrifter
            Big Booty Daddy
            • May 2010
            • 3278
            #185
            Im pretty sure they will be ok on and 80 amp esc's.If you go with the 120's you ll have more motor options later and they will run very cool with the 380 9 or 10xl's.I ran my EKOS with x442 props on the 10xl's and esc temps got to 117 degrees.Nice and cool.
            • JPriami
              N4FOX
              • 1675
              #186
              pulled my motors out to get ready to put new couplers on for wire drives. Found a 2881Kv sticker on them. So once again the boat I bought didnt come with what it was advertised as having in it.
                • 9488
                #187
                remember they all come from the same place
                and STICKERS
                • JPriami
                  N4FOX
                  • 1675
                  #188
                  Lol.. stickers seem to add Horse power to those rice burner cars too.
                    • 9488
                    #189
                    Ohhhh man!
                    • JPriami
                      N4FOX
                      • 1675
                      #190
                      My mistake they are 70 amp esc's. do you think the feigaos 9xl's will be ok on those escs? I see the 9xl's are rated at 47 amps?
                      • LarrysDrifter
                        Big Booty Daddy
                        • May 2010
                        • 3278
                        #191
                        They might be ok.Its worth a shot.Running in a twin,the motors dont work nearly as hard as a single drive.So the amp pull would obvioulsy be less.Theres only a 269kv difference between your stock motors and the 9xl's.The main thing is the amp draw difference.Which I dont know what it is.I think you can run the 9xl's on the 70 amp esc's.Just watch temps and prop small to start.
                        • JPriami
                          N4FOX
                          • 1675
                          #192
                          smallest props i have are the 36mm. mine didnt come with 32mm props.
                          maybe i should lean towards the 10xl?
                          • LarrysDrifter
                            Big Booty Daddy
                            • May 2010
                            • 3278
                            #193
                            Those will be fine.I think Steve has the 9xl's and jackets in stock now.
                            • JPriami
                              N4FOX
                              • 1675
                              #194
                              yeah he does. am im trying to sell my heli to pay for that stuff lol
                              • LarrysDrifter
                                Big Booty Daddy
                                • May 2010
                                • 3278
                                #195
                                Didnt you say you only have two 3s batteries too?
