Hota?
EKOS clone and upgrade questions.
Prime example Venom 60 amp, Turnigy Marine 60amp, Hobbywing Seaking 60amp. These are all the EXACT same esc's with different labels. Notice the venom inflationComment
I did notice that when looking at them all. I just wondered cause mines the 70amp and can run up to 6s if the card would work for it. but if it works with the 120amp esc and down to the 60 amp esc i guess im good being in betweenLand, Sea & Air, A true RC Addict.Comment
here is the sheet it came with for programming
it does say DHP speed controller programming instructionsAttached FilesLand, Sea & Air, A true RC Addict.Comment
Wow! That is complicated. I would read it a couple of times and reset your esc's. Do you set both at the same time or one at a time. I know the ekos sets them both at the same time, but sometimes the esc's dont beep at exactly the same time and it gets really distracting. I disconnect the y-harness and set them individually on mine.Comment
I should mention the water cooling lines are not like the one in the pic. the sticker is the same. but the cooling lines are run diffrently. they go in and out the same side. and its on the opposite side of the capacitorsLand, Sea & Air, A true RC Addict.Comment
Do you still have any boat hot rodding funds left?If so,buy two 120 amp esc's and you ll be covered for just about any motor you put in later.Hobbyhot.com sells the SeaKing 120 cheaper with the programming card than with out.Comment
