Boomer,I forgot to take a pic for you.I still use the stock teflon inside the stuffing tube.What I did was take apart the stingers.If you press the inner and outer bearing out,you will notice a teflon spacer that rides between the bearings.I replaced that with brass tubing of the same length and I think 3/16" diameter.The brass makes the stub shaft spin more freely than the teflon.If you take yours apart,you will see what Im talking about.Id have to take apart mine again for a pic,which wont happen for a long time I hope.Hope this helps you.
SeaKing 120 esc
Ran the boat twice today.It stays mostly dry with only about a 1/4 teaspoons worth of water that comes in through the stuffing tube on one side.Much,much better than before.I did flip it the 1st time out and the hatch tape failed.(Always does).Got quite a bit of water that time.It runs very solid and close to the water with the batteries in the sponsons.Ran the 38mm props today.Water was smooth.I didnt GPS it though I should have.Im considering selling my 380 9XL's and jackets.Thinking about 540's.Arc has some that are 4 pole and I think 2800kv for a little hotter 4s set up.Comment
Ran the boat twice today.It stays mostly dry with only about a 1/4 teaspoons worth of water that comes in through the stuffing tube on one side.Much,much better than before.I did flip it the 1st time out and the hatch tape failed.(Always does).Got quite a bit of water that time.It runs very solid and close to the water with the batteries in the sponsons.Ran the 38mm props today.Water was smooth.I didnt GPS it though I should have.Im considering selling my 380 9XL's and jackets.Thinking about 540's.Arc has some that are 4 pole and I think 2800kv for a little hotter 4s set up.Nortavlag Bulc
are you guy having any problems with the cf-40 props?
i shreded 3.
put the 442's on and no probs yet with twice as many runs.Comment
I never bought the cf-40 props.From the sounds of it,forescott hasnt had problems,but only he can atest to that.I run the 38mm from Kintec and 442's.Ive heard of people shredding non metal props,so me being paranoid,I dont buy or run them.Even though metal props cost more-especially when you lose them.Comment
Have you upgraded your EKOS yet scuba?I never saw anything on here and I remember you were saying something about 10xl's a while back.Comment
YES SER....
posted in 4s like butter thread a couple ago.
she screams now and stays cool for the duration of the packs
approx.12-15 mins(5000mah 20c) top speed 58 ish average speed
56 ish,,,flipped a few times untill i gotter trimed up but now she moves out
corners great and stays stable enough for me to race my buds
the 10xl & 442's were the ticket for me..i'll post some vids and pics in a little.
how are you doing after the crash?
she looks good!
stick with the 38's and the 9's at these speeds she still handles
good in the chop with out having to back off at least in the puddle
i run in....Comment
Ill check out your thread.Would like to see the video too.I got it fixed and strengthened at the same time.I posted some pics on here a page or 2 back from this one on this thread.Comment
