Setups
  • OldSoldier99
    • 47
    #46
    Originally posted by NitroVal
    Did you get the red props or the "as-cast" props. The red props are CNC'd and shouldnt need balancing. The "as-cast" ones do need balancing. There is a possibility the step up in prop size may have been too much. The stock plastic props are only 32mm in diameter.
    I got the "as-cast" props not the red ones. I noticed that the blades did not look particularly sharp. I guess you get you pay for as the red ones are expensive.
      • 9488
      #47
      I think all metal props do not come with a sharp edge.. no biggie just a little work to make them sweet!
      • OldSoldier99
        • 47
        #48
        Almost got to 50MPH
        OK, so I sharpened the blades, but did not balance them. I've never done either before, but I understand the concept. I did not have my balancer with me. I assume its done the same as with plane propellers. I have balancer that I use for plane propellers. Anyway, I got 48MPH on this run!!
        Again I failed to take temps.
          • 9488
          #49
          Yes!
          great job man..
          looking at your wires, if you redid them I can see a couple more mph!
          • OldSoldier99
            • 47
            #50
            Nitroval,
            How would my boat do using your x442 blades and my 4s stock setup?
              • 9488
              #51
              those could put a strain on your motors?
              alot of prop on 4s
              • Rumdog
                • 6453
                #52
                No need to balance aluminum props guys, just sharpen em up!
                • OldSoldier99
                  • 47
                  #53
                  Thanks for the tip Rumdog! So now I have another question... I noticed after my 48MPH run that the boat was running kind of strangely. It sounded like the props were slipping or something...especially at lower speeds. Seemed to drive OK at full throttle. Didn't sound right at low and mid throttle range. I put new grease in the tubes and checked my set screws (except for the motor pinion set screws that can't be reached because of the motor brace.
                  I know this is a poor description, but any ideas??
                  • Rumdog
                    • 6453
                    #54
                    Sounds like a loose coupler. Check all the set screws. It may also just be that these props cavitate more during launch and slow speed, then once on plane hook up well. Make the leading edge as sharp as you can while trying not to affect the shape of the prop at all.
                    • OldSoldier99
                      • 47
                      #55
                      Trying to get 50MPH via a loophole ;-)
                      I noticed on the way home from the lake that my GPS reads 2MPH lower than my car on cruise control. So can I count this a 50MPH?
                      • OldSoldier99
                        • 47
                        #56
                        GPS in the hull now
                        how'd ya get it out of the boat with the hatch still taped up?
                        Hey Rumdog... I cut some foam out of the canopy and stick my GPS device inside the hull now. I Still don't know what I missed on the inside joke earlier in this thread.
                        • Rumdog
                          • 6453
                          #57
                          Ahh, Nitroval was implying that I didn't believe your gps reading because of my comment about your hatch.
                            • 9488
                            #58
                            smaller props do this vs lager props..
                            samller props take a bit to hook up
                            • NitroVal
                              • Jun 2009
                              • 423
                              #59
                              I wouldnt run 442 props with 4S. I ran the 442s on 3S and the ESCs and batteries were pretty warm after each run, plus I babied it during acceleration.
                              As for the inside joke, some people on here want video confirmation, 3 witnesses, one being a municipal judge of good moral standing, one being a priest and an the other an ex-girlfriend, a voice recording of verbal confirmation, a letter from god, and a horoscope reading from that day in order to believe any attempt at any speed..
                              The RTR Nightmare- Electric King of Shaves
                              Now with 540s- 62mph
                              New setup- Etti 150A's, Turnigy 2600s, 5S, X442s and a whole lot of cooling hoses
                              • OldSoldier99
                                • 47
                                #60
                                Ahhhh now I get it!! Just remember...OldSoldiers never lie
