M41 esc over heat
  • busstoff62
    • Aug 2018
    • 22
    M41 esc over heat
    Stock motor stock esc
    Stock prop
    Fancy water jacket fer motor
    Duel water intake rudder
    VX90 connectors on 7600 3s 75c Batterys
    HELP!!
    I get 5 min of bashing & it shuts off
    If a baby it I get 10
  • Revolt Flash
    • Aug 2015
    • 437
    Stock prop
    HELP!!
    We have been only able to get about 3 1/2 minutes on 6s with stock setup. 5 minutes is pretty long on 6s.
    • busstoff62
      • Aug 2018
      • 22
      Ok I had some 50c Batterys in it & was able to run it fer about 15
      Cheep China zop
      Also I melted the traxxas connectors with75c. Are the batterys to much.
      Is there a motor esc combo I should look at
      • Revolt Flash
        • Aug 2015
        • 437
        Shorten your run times up to 3 minutes and keep check on the temps such as your batts ,esc and motor. If the temps are good then run it a little longer. The M41 is just like the Spartan when it comes to the electronics. Make sure you grease the flex cable about every 2 to 3 runs.
        • busstoff62
          • Aug 2018
          • 22
          I grease prop shaft every other time
          Remove motor & oil berrings this concern happened when I went to 75c Batterys Is it worth to upgrade esc?
          4082 1600 ? Motor ?
          • boatsrnew2me
            • Oct 2016
            • 476
            i use ec5`s on all my boats .even my spartan and i have got some great run times .i can get between 8-10 minute run times with mixed fast passes and cruising around .in theory the cat should get the same or more since its skimming on the water .the spartan is a displacement hull . if your hard on the throttle the whole run your going to heat the esc up .its already on the edge .
            volantex vector pro ,proboat veles 29 , traxxas spartan, hobbyking/tfl pursuit ,ft009 with rescue rigging
            • busstoff62
              • Aug 2018
              • 22
              That’s all understood
              But not solving my concern
              I want a longer run time so I may run with buddies nitro. Oh ya & leave him in my wake
              Shal I upgrade esc or both esc & motor
              It’s fast ,,but shuts off too soon need about 10 min of run time
                Ten minutes isn't going to happen. For 7600 mAh packs to last that long you’ll need to limit the average amp draw to 50 amps. That’s not going to be very fast. And heat buildup will be an issue too. Ten minutes of mostly WOT is tough to achieve with any FE boat. And running a lot of part throttle will heat up the ESC even more. There are Spartan owners who have a lot of success modding their boats, hopefully they will chime in.
                • Revolt Flash
                  • Aug 2015
                  • 437
                  I have had both and what fluid said is true.
                  • busstoff62
                    • Aug 2018
                    • 22
                    So,,, I have come to the conclusion my motor is failing I took both boats out & spartan was way faster m41 was struggling to go at partial throttle. Had to give it full throttle to get it up to any great speed
                    So,,,, my question is.
                    What to replace stock components with
                    I don’t mind spending $ if it is worth it
                    Help I need. Please
