Prop Question
  • Kramerr
    • Sep 2012
    • 14
    Prop Question
    I am setting up my Spartan to run a Castle Ice Hydra 240A ESC with the Leopard 1600KV motor. Which prop should I go with this setup????
  • egneg
    • 4664
    try a Otcura M545
    IMPBA 20481S D-12
    • Kramerr
      • Sep 2012
      • 14
      I was thinking on using an Octura x442...... Would this be a bad choice ??
      • patte6596@rogers.com
        • Nov 2011
        • 75
        The octura x442 is the stock prop for spartan. If you go higher, be careful. I ran a x642 with stock esc and motor, and it melted the esc. Other options maybe X445, x642, and prather s220. Good luck.
        • egneg
          • 4664
          With a 1600kv motor a large prop will be needed to get speed. And with that esc a larger prop shouldn't be a problem.
          IMPBA 20481S D-12
            • Nov 2011
            • 75
            No, shouldn't be a problem. I run the stock motor, and the hydro ice 200 esc and dual water pickup. Temperatures seem to be very cool. Will be trying other props next spring. Enjoy.
              • Nov 2011
              • 75
