Motor/Esc Recommendation for Spartan
  • mojogator
    • Jun 2012
    • 16
    I have a new Spartan running dual 3s Traxxas 8400 mah 25c batteries and I am looking to upgrade my motor and esc. I know that a lot of people are doing the standard leopard motor / seawing esc combo but I wanted to see what other options exist. I was talking to somebody about a neu 1521 1 y with a Hydra Ice 240 esc. Any thoughts on this particular configuration? Any other recommendations?
    Thanks
    Matt
  • dana
    Banned
    • Mar 2010
    • 3573
    Neu motor is much better to start with. 1521 would crank in that sucker!
    • mojogator
      • Jun 2012
      • 16
      Thanks for the recommendation, dana. Any other combos I should look at?
      • Make-a-Wake
        FE Rules!
        • 5557
        Please dont take this wrong, but you'd be putting a Ferarri V12 in a Cavalier. You will spend way more on those two items than the whole boat was ever worth...................then you have an ABS hotrod still.
        Stick with a 4 pole Leopard 4082 or 4092 in the 1400-1600kv range on 6s, the 4092 will most likely be faster than a 1521 anyways.
        • dana
          Banned
          • Mar 2010
          • 3573
          Make a wake has a point....
          • dana
            Banned
            • Mar 2010
            • 3573
            On the other hand, the Neu will run cooler
            • mojogator
              • Jun 2012
              • 16
              I really appreciate your candor, Make-a-Wake, and take no offense. Money is not the concern with this boat and with the custom paint job planned for the fall and the other parts that I already have invested, this is a ridiculously expensive boat. I will definitely look into 4092.
              • Make-a-Wake
                FE Rules!
                • 5557
                If this motor is still here when you log back on you could run it on 5s:
                http://forums.offshoreelectrics.com/...nious-for-sale
                • mojogator
                  • Jun 2012
                  • 16
                  Thanks for the recommendation, Make-a-Wake. I only have 3S packs. Do you think that would support a 6s run?
                  • Make-a-Wake
                    FE Rules!
                    • 5557
                    I wouldnt do it........................5s is pushin it but it can handle it with a tamer prop.
                    • mojogator
                      • Jun 2012
                      • 16
                      Roger that. Thank you very much for all of the suggestions; I sincerely appreciate it.
                      • dag-nabit
                        • Feb 2011
                        • 775
                        I concur with what has already been discussed.
                        I run a 1515 2200kv with a T180 ESC and X442 prop on 5S in one of my Spartans, and it has been solid so far.
                        Prior to running the 1515 on 5s, I cooked a T180 ESC trying to run a Leopard 4074 2000kv on 6s with a P220 prop.
                        This gives you an idea of how close to "on the edge" you will be running with high kv motors on 6s.
                        Kevin
                        • mojogator
                          • Jun 2012
                          • 16
                          Kevin
                          Kevin,
                          Thanks much for the insight. I know that we have talked about this on another board. What would be your feeling on running the 1515 or the 1521 with an X442 or M445 with a 240 ESC? Would the 240 mitigate the 6s in your opinion?
                          --Matt
                          • dana
                            Banned
                            • Mar 2010
                            • 3573
                            The Neu motors will swing those props with ease. As far as motor size I wouldn't go smaller than 1515 or Leo can size 4082. As far as kv, on 6s your best bet is anything 1600kv and under. Any more you risk motor damage. Using a big esc to mitigate using high voltage on high kv will only result in burning up your motor. Sure the esc might handle it, it's your motor that will suffer.
                            • dana
                              Banned
                              • Mar 2010
                              • 3573
                              That being said, I also run 1515 2200kv on 5s in a mean machine, but I'm swinging a small prop. M440. I would never have tried this with a Leo motor of the same kv
