I just got the spartan and was wondering whats a good choice for lipos? Im running Aquacraft 2s 5000 mah 40c.... Im trying to get more speed without blowing up my new boat... any suggestions???
lipos for the spartan...
Tags: None
I'd get two 3s of the same brand and "c" rating, then you will have two sets of batts to run 5s................which is best for that 1800kv motor..................6s is too hot a setup for that boat in my opinion.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
* Only run 6s if you like surprises.... SURPRISE YOUR BOATS ON FIRE!!!
ya I said no to 6s when I got the boat... prob gonna stick to 3s and have some reliability....Lakeside entertainerComment
What to expect from 5s
Here is my GPS from Tuesday's 5s run on a basically stock Spartan with Octura X442 balanced/sharpened prop. Still can tune the hull a little more and squeek out a little more. It's fun and will definitely get peoples attention without getting out of control. There's something to be said about the peace of mind and not pushing the limits too.
NICE. 5s is much MUCH better for that boat!Comment
Here is mine on 6s, its all I run. Traxxas 5000. mah and Traxxas 8.400 mah. I am bone stock other wise, no trim adjustments, no special water cooling, just stock Spartan everything. I never have the problems some are claiming and would not consider anything less. No heat problems that I keep hearing about, the lipos just get warm not melting down like the stock nimh's do. A just warm motor and warm esc at best after a hard run.
You tell me if this Spartan is running right, I have not raced one yet but have put away many a nitro boat on our lake. But the fact is I just have no other Spartan to compare it to. But you'll notice no fires took place after a long run. Thr 5000 mahs are lighter and will run a bit faster.
