Traxxas 11.1v 8.400 mah lipos are HUGE
Yeah, I just looked up the prices. What a rip. I'll never overpay for a lipo, again.
Checkout...
http://www.hobbypartz.com/sky.html
You always have great finds man!Only 25c, but they pump out 210 continuous amps..........more than double what the motor pulls.
Warlock...............you may have, or still may, consider two 6s packs to run 6s2p with the same, or more, mah as the 8400's.
Two of these will give you 8000mah and 320 continuous amps for $108 total - http://www.hobbyking.com/hobbyking/s...arehouse_.html
Two of these, 10,000 mah and 400 continuous amp discharge for $118 total! - http://www.hobbyking.com/hobbyking/s..._6S1P_40C.html
and it helps us FE guys save lots and lots of cash!!.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
You know I did the same mod with the grommet to keep the grease in, and had very good results with still quite a bit of grease left all over the cable pretty much and just as you said, I had a bit come out the oil hole on the strut. A good improvement, simple and cheap, "Kinda like me"Man, you sure have that thing running nice! I'm not sure I would change a thing performance-wise. I mean obviously the cooling mods would be nice because you are definitely getting some long 6s runtimes now. I also did that mod where you stick a rubber grommet between the strut and transome. All of the grease stayed in the stuffing tube with the exception of a small drip from the oiling hole on the strut. That's a $2 mod that's well worth it. It's the cleanest and driest (in the hull) my boat has been after a run.
Also, my 5s should show up today but I won't be able to run them until all of my connectors and wires arrive so I can make a parallel connector. Maybe then I'll make a video.
How do the Zippy compare to the others like Gens Ace? I have a couple new 5s Zippys sitting here waiting on my connectors and wires to arrive from Hong Kong. I'm dying to try them out.Comment
I just did the mod and it's pretty cool. I forgot to grease the drive line the last time I ran it had a little bit of rust on it. Sucks, but hopefully it will hold up better.You know I did the same mod with the grommet to keep the grease in, and had very good results with still quite a bit of grease left all over the cable pretty much and just as you said, I had a bit come out the oil hole on the strut. A good improvement, simple and cheap, "Kinda like me"
