what kind of connectors am i going to need?? my understandings are the seaking esc180 is 10 awg wire so what size bullets do i go with?? and are traxxas connectors good for the lipos??? btw the motor is 4082 1600 leopard.
leopard and seaking wiring questions??
Hey I have a quick question, leopard 1400kv motor on 6s, will a octura 447/3 and or a Prather s230 be ok? Or can I use both? Thanks....Scott Spartan#1: castle hydra ice 240 castle 2200 Prather 220 turnigy 5.0 45c lipos with max amps water pump... Spartan#2: leopard 1800, octura 440 ,traxxas 8400 mah 25c lipos.....updated deeper hull....Comment
Any thoughts on the prop I should run?Scott Spartan#1: castle hydra ice 240 castle 2200 Prather 220 turnigy 5.0 45c lipos with max amps water pump... Spartan#2: leopard 1800, octura 440 ,traxxas 8400 mah 25c lipos.....updated deeper hull....Comment
Ok thanks.... I started 2 threads a couple days ago and didn't get ant replies . Don't mean to just barge i'n on your thread but, wanted to know what people thought about using those props.... Thanks again& hopefully I'll get some replies....Scott Spartan#1: castle hydra ice 240 castle 2200 Prather 220 turnigy 5.0 45c lipos with max amps water pump... Spartan#2: leopard 1800, octura 440 ,traxxas 8400 mah 25c lipos.....updated deeper hull....Comment
I run 5.5mm bullets on all my batts even on the cars I use to have before I sold, so everything is standard. I keep things simple, 5.5mm on boats, deans on my planes that's it. I personally HATE the traxxas connectors, annoys me even more that traxxas gets there panties in such a bind over those stupid things... (me ranting ignore), but on my motor bullets I prefer 5.5mm on the smaller 3656 motors 6mm - 6.5mm on the bigger leopards and I have 8mm on the bigger castle motors. On that Leopard of yours I would go CC6.5 if you want the quick or if you have time I really am starting to like the 6.0mm bullets from Hobbyking. JMHOComment
I finally got to run my Spartan on the weekend with the 3674 1700kv, but so far I have only run an S215 prop, so don't have a lot to draw on to give you any insight.
KevinComment
Ok thanks! How did your Spartan go? Any issues? I know you'll post pics/videos but just curious...... I have the 447/3prop on there now and gonna run it soon...... Maybe this weekend. Thanks again! And good luck with yours !Scott Spartan#1: castle hydra ice 240 castle 2200 Prather 220 turnigy 5.0 45c lipos with max amps water pump... Spartan#2: leopard 1800, octura 440 ,traxxas 8400 mah 25c lipos.....updated deeper hull....Comment
