Installing Seaking/Turnigy 180A ESC in Spartan
At Brandon's request I'm re-posting pics from OP that have the links messed up.
Lexan Plate - Drilled and Counter Sunk
Lexan Plate - Installed with double sided tape and bolts
Lexan Plate with Self Adhesive Velcro Installed (yes I know it is crooked)
ESC Installed - Caps clear the rail - you can see the layers of Lexan and Velcro.
KevinComment
Hey Kevin on my seaking programmer for the lipo cells, setting i have 1-6 and i have it set at 3 cells and then i'n () it says 6 cells with a star that means high voltage esc. Is this the correct setting? Or should it be set on number 6 which is 6 cells or 12 cells high voltage esc ? Thanks fir your help!Scott Spartan#1: castle hydra ice 240 castle 2200 Prather 220 turnigy 5.0 45c lipos with max amps water pump... Spartan#2: leopard 1800, octura 440 ,traxxas 8400 mah 25c lipos.....updated deeper hull....Comment
Ok that's what i thought i have the hobbywing pgm card so #6 it is.... Just confused me because i'n () it says 12 cells..... Thanks for your help...Scott Spartan#1: castle hydra ice 240 castle 2200 Prather 220 turnigy 5.0 45c lipos with max amps water pump... Spartan#2: leopard 1800, octura 440 ,traxxas 8400 mah 25c lipos.....updated deeper hull....Comment
