Spartan, tear it down to build it up
.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s -
what setup did u run today to get rid of chine? I tried mine 4.5MM strut and batteries all the way back and tabs all up. little chop, chine walk YES.....Did run fast though but i couldnt hold WOT due to chineGenesis (Bosncali Geico Beater) Leopard 4082 1500KV
(63.7 MPH) Traxxas Spartan (same setup)Comment
Loosen the strut mounts and shift the strut up and to the right then re-tighten themComment
.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
Brushless, thats what I used, adhesive-backed 1/4 " foam. It comes in a roll from Home Depot. I inserted it in the groove the hatch edge fits in. Also across the back of the deck, immediately in front of the transom but behind the drain hole. Its snug pinning the lid down but to me thats not a bad thing....yet. As an added measure I put a small strip in each of the lid "overhangs" (the ones Dag-Nabit removed). It works well.Comment
With my current setup I moved the batteries midforward a little...same 4.5mm strut which is slightly positive and wobble was gone but speeds were 42 but my packs were almost ready to cutoff. I can run 42-43 with no chine walk but thats not fast enough. 44 and up u get chine. maybe my spartan is maxed out and time to upgrade. I think low 50's with no chine i would be happy. maybe a T180 and Leopard 1450-1600kv is in my near futureGenesis (Bosncali Geico Beater) Leopard 4082 1500KV
Will I be Ok if i use the traxxas high current connectors with an upgraded setup? I like to keep all my bats the same and I have some 2S that i would like to try when its upgraded but i also use them on my slash so I would like to keep traxxas connectorsGenesis (Bosncali Geico Beater) Leopard 4082 1500KV
I upgraded to EC5 connectors, but only to be standardized between all my boats, not because I thought there would be issues with the Traxxas connectors.
KevinComment
Good run today, very windy some a little chop which turned out better. 48.0 MPH on stock setup (must have been down wind though) 4.5MM strut, Rt side tab down a little, batteries in the middle, GPS up front. 48mphGenesis (Bosncali Geico Beater) Leopard 4082 1500KV
ambient 48*f
Run#1 2x 2s P225
esc: 73* motor: 96*
Max amp: 95 speed: 39 mph
YT vid
Run#2 2x 3s
esc: 75* motor: 103*
amp: 87 speed: 42
YT vid 1
YT vid 2
Run#3 2x 3s
esc: 75* motor: 107*
amp: 91 speed 42
YT vid
So not blazeingly fast today.
I had a P225, prop did work well on 4s though
Maybe they should have had one on it out of the box, but I think that the power required is more that the stock NiMh can provide.
packs were pushed to the rear, so that is the cause of the slight chine walking.
Run#2 rudder needs to be square to run/cool right. Not sure why I get a dry lube squeak on the first 6s run, maybe it's the collet
I have setup tweaking to do, other tweaks are proving themselves quite useful thoughLast edited by GeoVW72; 04-07-2011, 12:32 AM.Comment
Thanks George for putting on the bigger prop while running 4s!
so maybe to some running 4s2p with a bigger prop could be a nice way to go with this boat?
10,000mah of runtimes and fair speeds.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
NP BL55 happy to take any suggestions, that setup sounds pretty good. The boat didn't have the same get up and howl attitude it has on 6s and it did chew through the 5200mah pack faster than before, but any setup that doesn't burn the thing up is good in my book
Tore some things apart today
motor really stinks now
rotor epoxy browned a little bit and the back end of the shaft has a shine to it.
So had to bust out a tweak that I think should have been factory:
I'm hopeful a Thrust bearing can take a good load off the motor. re-lubed everything.
Also found some damage I missed from the stuffing tube heat
melted the coating off the temp sensor wire.
More data tomorrowComment
How about trying 5s on this sucker?.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
