7-cells or 6-cells? I'm curious as to how the boat is really going to run on NIMH's, that's what i'll be using the majority of the time. You can run one 2s pack and one 3s pack in the Spartan (5s) as long as they are the same MAH and C rate right?? 5s would theoretically get it to about 40mph roughly. That may be my other option.
Traxxas Spartan
I am going to run 4s, 5s, and 6s and see how she runs
I hope to see 50mph on 5s!.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
Ok, here's temp and amp data. Again the GPS unit didn't record. I've got to play with that a little more. I ran it on 4s until I got bored and then 6s. It took on some water today so I wasn't going to sacrifice my cellphone. 4s was a continuous run, 6s there are 3 runs. I had a Garmin 855 in and I recorded high speed of 44 but the boat was bouncing back and forth so I brought it in and removed the GPS. Second run it was also bouncing around and I found the rudder tilted up so I moved it back straight and went for the 3rd run. There is no place to hook up the eagle tree so I had a 1500 3s battery powering it and I would imagine the weight of that plus the GPS would add up almost to another 3s 5000 battery.
If you take enough readings you can tell becaue they just wont be consistant. With a good signal my RCs will duplicate the same mph over and over.
Im not sure if you have room in the spartan, but I have put my gps inside a tupperware container that I velcro'ed to the hull in some of my larger boats. Its good insurance if you DO happen to take on water!Comment
The motor/esc will try and pull whatever current it needs to get the job done. When the batteries cant supply teh required current, the voltage will drop. The voltage will most likely end up lower with the nimhs under load.Comment
What kind of problem are you having with the GPS? I ask because if its not recieving a good strong signal, it will not read accurately. I've gotten high 70's out of a 60mph boat when I had a weak signal. I notice the same in my car, sometimes going under bridges, ect, the mph will jump up for a moment.
Traxxas got the carbon props from me to test that boat. If they ended up with a 42mm prop there is no guarantee that a x442 will be better. I've run a 2317.42 Graupner and a x442 in one of my race boats and the 2317.42 was faster. I'm sure someones going to ask, so yes the x442 was sharpened, thinned and balanced.Steven Vaccaro
Traxxas got the carbon props from me to test that boat. If they ended up with a 42mm prop there is no guarantee that a x442 will be better. I've run a 2317.42 Graupner and a x442 in one of my race boats and the 2317.42 was faster. I'm sure someones going to ask, so yes the x442 was sharpened, thinned and balanced..NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
I dont remember. It was back in 2005 at the nats. But it was enough difference in take off speed that I had to quickly switch back to carbon. Please DON'T take this the wrong way. I'm sure I could have found a faster metal prop. I just didn't have the time to do it. I'm just trying to stop people from buying expensive props that "may" be close and not make much of a difference. Which prop is best on the stock Traxxas setup is going to take some testing.Steven Vaccaro
I have one of these Spartans on the way.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
I sure hope the 50mph advertised, is not the tops of this thing
stockLast edited by Brushless55; 01-08-2011, 09:38 PM..NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
