Painted my Voracity
  • Crash
    • Oct 2015
    • 313
    Thanks, it was a challenge cutting out the gold from the decals but, was worth the effort.
    on a different subject, I purchased a couple of balanced props off the web and thought I had a grasp on the size and pitch idea.
    Now that the props are here I'm not sure I made the rite choices, what do you think of the Octura x548
    and the x643 for the Voracity on stock set up?
    Dan
    • arrover
      • May 2015
      • 322
      I think the x548 may run similar to the stock prop but I haven't tried it on a stock boat. I don't think Octura makes a x643. Are you sure that's the correct number?
      ProBoat Zelos 36 Twin, Voracity 36, Impulse 31, Stealthwake 23, and HobbyKing Flowmaster Videos
      • Crash
        • Oct 2015
        • 313
        thanks
        here is the x643 listed on ebay I bought.
        • arrover
          • May 2015
          • 322
          I don't believe that is an Octura prop. I think they use the name Octura in the add to get in the search results. Besides that, it looks like it should be a nice prop. It's less aggressive than the stock prop so it may be slower. It's always tough to tell though before you try it!
          • Crash
            • Oct 2015
            • 313
            just got back from maiden voyage for the season and after assembly from paint job.
            Boat ran perfect, no issues.
            after the lvc kicked in I brought it in and the motor and ESC were cool battery wires were hot, battery was warm .
            Is there a way to ease the stress on the battery? will timing change help?
            Dan
            • Crash
              • Oct 2015
              • 313
              I ran this prop today
              its just not enough prop for this boat, I was on full throttle a lot more.
              Now I have a prop for sale
              • LuckY07
                • Jul 2016
                • 56
                Originally posted by Crash
                Thanks Dan
                Its been nice whipping this hull into shape
                only had 2 real issues that I didn't like, the hull would of been fine as is.
                I found the seam between the top of hull and bottom of hull had some hollows and very thin where the 2 pcs meet.
                I added 1 layer of FG to the hull seam on sides and rear of boat at seam.
                Then I added 1 layer FG on the bottom inside boat on sides, center and rear area .
                I also added a layer around inside the canopy .
                It made a dramatic difference in overall stiffness in the flat areas
                I am very pleased with the FG work
                The paint is a lacquer
                I am considering vinyl wrap from Darkside Studios on ebay but, they don't have a Voracity hull to digitize from yet. Id have to send them a hull to digitize a pattern
                [ATTACH=CONFIG]139369[/ATTACH][ATTACH=CONFIG]139370[/ATTACH][ATTACH=CONFIG]139371[/ATTACH]
                Looks really good. I just bought a Voracity (stock for now) and was considering doing the fiberglass/epoxy before I use it, to prevent cracks.
                What size/type of fiberglass did you buy? What epoxy did you go with? Any big difference after adding the added weight?
                I also noticed you didn't fg the bottom section of the transom, where the prop goes. Is it best to leave that area alone? Thanks!
                • Crash
                  • Oct 2015
                  • 313
                  #23
                  I am still running this rig.
                  It recently got some new parts:
                  TP 4060 1750kv. on 5s 4000mah 60c x two running parallel
                  300 amp SF
                  652 OSE CNC prop
                  68mph
