New owner, some questions on salt water use / after run / setup
  • tlandauer
    • 5660
    #31
    To be clear: think of your ESC as a electrical gate; the on and off and partial throttle is making it working hard, the ripple current is the killer, that's why you see extra capacitiors on some ESC. People also install what they call 'cap bank" for this reason. So the only alternative way of gaining more run time is to get higher capacity batteries and running a smaller prop. Smaller prop usually is used when a slower speed is desired in testing rather than using part throttle.
    • Tharr62
      • May 2014
      • 42
      #32
      Very nice! I totally understand what your saying! Thank You! :-)
      Can I ask you..
      Which way do you personally think I should go with the drive shaft?
      a. the upgraded one with no liner. (0.187)
      b. the upgraded one with the liner. (0.150)
      What will give me the best results, and the most reliable boat / water tight / and logjevity?
      • tlandauer
        • 5660
        #33
        To be honest, I don't know, because when I built mine without using the liner, the brass tube is 1/4'' , and it is K&S brand, it is Made In USA, very good tubing. On some Chinese made boats ( I don't mean PB at all but I don't want to point out which brand it is) the tube is metric sized and the wall is thinner, less quality. But I am sure PB is OK, since OSE is selling this up graded cable .
        Question is this: Have you already ordered the .150 one? If so, can you still change the order? If not, run the .150 first and once or twice removing the motor and pulling the liner won't kill you, ( forgive me, couldn't resist)
        If you have not ordered the .150, then by all means get the .187 from the get go.
        • capnswanny
          • Feb 2012
          • 817
          #34
          tlandauer you are awesome......thanks for being sooooo helpful. Guys like you keep me coming back every day for more!
          Here's a product I use on my full size sailboats and stink-pots running in the Puget Sound (salt water):
          http://www.amazon.com/gp/aw/d/B00144...&robot_redir=1
          It's an amazing product that extends the life of any watercraft running in salt water.
          A spray bottle mix of this stuff squirted over your boat and through your cooling system will wash the salt away post-haste! Follow up with a quick fresh rinse and you're golden!!
          I only run my SV27 in the salt so I will abstain from anything boat specific. But honestly, if you tape up well and keep the water intrusion into the hull to a minimum (none is best...of course:) you will have a lot of enjoyment!
          With the excellent advice you're getting here and your maintenance minded attitude you will have GREAT success!
          This is NOT a toy?!?
          • tlandauer
            • 5660
            #35
            Thank you sir for the compliment! I am merely passing on the limited knowledge I have to a newer member. I love this Forum and on days I am not working and RC boating or building, I enjoy going through this place!
            Thank you also for the link, I think I will get some, a friend of mine has a real luxury yacht, he had invited me to run some of my boats in the marina, so I think armed with this and your invaluable input as well as other people's feed back, I am ready to rock!
            • Tharr62
              • May 2014
              • 42
              #36
              Just a thought today.. is it alright if I run the stock prop for some test runs? I'm not going to be able to sharpen or balance it.. as I just will order a new one that it's already done (although I see ALL of the OSE props that are pre balanced are out of stock?). Which.. BTW.. any thoughts on what that prop should be? Again, I will be running all stock gear on 4S.
              Thanks guys!
              • tlandauer
                • 5660
                #37
                M445, http://www.offshoreelectrics.com/pro...rod=octsb-m445 , IMO
                Some of the K series non-metal props are good for testing. Doby here is extremely experienced and he uses them regularly for this purpose.
                42mm would be good to start:http://www.offshoreelectrics.com/pro...od=grp-2317.42
                You may try the 45mm prop.
                http://www.offshoreelectrics.com/pro...od=grp-2317.45
                The newer CNC props are very good and gaining popularity, they are balanced, but a little blunt on the leading edge and shouldn't be too hard to sharpen.
                Anything between 42-45mm would work well on your boat. Always start on the smaller dia.
                http://www.offshoreelectrics.com/pro...+2+Blade+Props
                Yes, you can run the stock prop for testing.
                • Tharr62
                  • May 2014
                  • 42
                  #38
                  Excellent. What size is the included stock prop?
                  I just wanted to be sure that I will not damage the boat by running the stock prop, without balancing and sharpening?
                  Is there any other place I can buy on pre balanced sharp etc.. online? OSE is all out of about everything it looks like :-(
                  Chief, posted and sent me the info manual he has on the boat.. and I just noticed that he mentions a X642 prop..
                  Whats the main difference with the M445 and the X642 etc.. Which one is best to use with my stock gear / connectors etc.. on 4S?
                  EDIT - I wanted to ask about this video I saw.. Looking at this video, the water looked pretty calm? but, you can tell the performance of the boat was NOT GOOD! Even being new to boats, I can tell that. Lets say, that this is what I see when I have my first runs.. what are somethings that would have improved this persons run?
                  • tlandauer
                    • 5660
                    #39
                    You want the M445, not M455, may be it was just a typo.
                    The X642 is also an excellent prop to have in your parts bin. It is a 42mm prop vs. the 45mm ( as with the M445), but with more pitch. For every 360* turn it will go 2.64 inch vs. the M445's 2.478 inches. Also the "X" prop is not de-tongued. It will load up a bit more than the de-tongued "M" series.
                    On paper the X642 should have more speed, but in the real world it maybe different: depending on the hull and set up, the "M" series with its de-tongued feature allows the motor to "rev" freer, thus may be the opposite. But too large a prop in the diameter regard with mono boats can sometimes give chine walk. Ideally you need to have all these props to experiment.
                    When I said load up more, it can be translated as more heat ( more amp draw) on your motor, ESC and battery. Note that if you are running stock, these variances may be small.
                    You should do a search to understand props and also what is de-tongued. I will never be able to explain to you clearly in a post like this.
                    • tlandauer
                      • 5660
                      #40
                      Here was an interesting discussion on the VERY prop that you have now from PB, the link:
                      http://forums.offshoreelectrics.com/...-prop-question
                      Apparently he has a much better stock Proboat prop than I 've got. Go figure.....
                      • Tharr62
                        • May 2014
                        • 42
                        #41
                        So, basicly the M445 is a good choice, and won't stress out my ESC as much as the X642? Do you know of anywhere I can get one sharpened and balanced so I can use this out of the gate when I get the darn boat in the water? After reading that link you posted.. it was mentioned that the stock prop may not be a good idea to run.. and really should be at least balanced.
                        Tell me your thoughts on this video. How can one "tune" a boat so that it does not behave like this one did?
                        I mean, the boat was SO unstable! why?
                        • tlandauer
                          • 5660
                          #42
                          I do not have this boat, I DO remember Chief ( James) said the M445 might give chine walk, so it is a fine balance of choice when it comes to pick one over the other. I use a M445 and M545 on my Pursuit mono, both work great. I can only tell you my first hand experience on the Pursuit, sorry.
                          Chris ( dasboata ) is great, you can PM him and I believe he will reply quickly.
                          http://forums.offshoreelectrics.com/...6326-prop-work
                          Last edited by tlandauer; 05-31-2014, 09:01 PM. Reason: Include Chris' USER NAME on OSE
                          • tlandauer
                            • 5660
                            #43
                            X642 should not stress too much on your boat, if you use a X646, then yes! lol...
                            • Tharr62
                              • May 2014
                              • 42
                              #44
                              Are there any other sites that you know of that sell pre balanced and sharpened props? Now, I don't want to run mine without one. afraid I will damage the bushings in the strut from a bad factory balanced prop.
                              arggg.. now more time need to wait till I get it in the water :-(
                              • tlandauer
                                • 5660
                                #45
                                Well, first of all, those guys are running part-throttle, on 6s, they did not say if it is stock system, but they are stressing the hell out of the ESC.
                                The boat is running loose, strut and trim tab need to be carefully adjusted. Water was choppy...
                                When the hull is out of water like that and if they are using a pretty good sized prop, the hull is experiencing torque-roll, that's why it flipped. I believe the strut angle is wrong, not to mention the trim tabs. They should have made the boat run well on 4s first.
