28.7mph on 2S
  • Mtwinste
    • Jul 2011
    • 135
    Ran tonight with x445 prop and 3S2s gens ace 5300mah 45c and burned up something. Motor or ESC not sure. Motor was way hotter than esc. Oh well I didn't really care I wanted to upgrade it anyways. Recorded 44.4mph on this setup before she blew and she was running pretty loose at that time.
      • 9488
      what are you saying? 3S2s??
      are you running two 3s packs in series or parallel??
      • Mtwinste
        • Jul 2011
        • 135
        Series. Stock electronics. Stock wiring. Series.
          • 9488
          this system is ment for 4s power the way you ran it was 6s
          to much voltage with that prop possibly burnt up your esc
          • kookie_guy
            • Jun 2008
            • 897
            Mtwinste, you need to be more clear when you are posting. 3S2S. what does that mean? Does that mean 2x 3s packs which means 6s total? Or do you mean you ran a 3s pack and a 2s pack in series for 5s total?
            • Mtwinste
              • Jul 2011
              • 135
              Series. 6S total.
                • 9488
                Series. 6S total.
                • Mtwinste
                  • Jul 2011
                  • 135
                  #23
                  Neither the motor nor ESC burnt. It thermaled bc it ran fine later on.
                  I bought a leopard 4074 1400kv and a seaking 180A today and will run on 6s
                    • 9488
                    #24
                    good to hear about the motor and esc doing ok!
                    try a different prop on the stock setup while running 4s
                    you will like it..
                    • Mtwinste
                      • Jul 2011
                      • 135
                      #25
                      Ran the x445 on two thunder power 2S 65C 6600mah in series. 43.4mph. Ran the batteries dead and the motor batteries esc everything was hot and even a little smoke came out from inside the hull!!!! Let it cool some and tried another pair of 2S packs and she was thermalled and wouldnt go over idle. New ESC and motor are on the way.
                        • 9488
                        #26
                        this is a solid setup from Proboat
                        sounds like your looking to see smoke on every run
                        • Rumdog
                          • 6453
                          #27
                          So you ran 6s on the stock setup. Probably did significant damage to the motor and esc, and then ran 6600mah packs till DEAD?! All I have to say is....WHY?
                          • Mtwinste
                            • Jul 2011
                            • 135
                            #28
                            50mph on 6S but very windy and sketchy. Seaking 180. Leopard 4074 1400kv. Gens ace 6S total in series. X645 prop.
                            • Mtwinste
                              • Jul 2011
                              • 135
                              #29
                              Tried again and got 54.1mph.
                              • Mtwinste
                                • Jul 2011
                                • 135
                                #30
