New Proboat Impulse 31" Deep Vee
Darin E. Jordan - Renton, WA
"Self-proclaimed skill-less leader in the hobby."Comment
For 2s1p, I just run normal 5.5mm bullets negative on esc to negative on one battery, positive on esc to positive on other battery, and the remaining two together.
If you have two 4s packs and want them in parallel, you'll need a y adapter on each ESC wire.
If you have 2s packs and want to combine them into 4s2p you'll need the two y adapters as well as plugging the packs together like I do.Light travels faster than sound, so people may appear to be bright until you hear them speak.Comment
Is proboat working on making the plastic lids work on more than one boat, theres a lot of boat out there that have them.Comment
If we can make it fit, it'll be there, unless someone higher up nixes the idea.Darin E. Jordan - Renton, WA
any word of the date this one will be out?.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
IMO it's not a huge deal since they all come with lids anyway.Light travels faster than sound, so people may appear to be bright until you hear them speak.Comment
This looks like a very interesting boat. I´ve got a Traxxas Spartan on backorder, maybe i´ll switch to this mono. Because i´m new to FE-boats, i do not know the reason why the teflon liner goes into the transom in a stuffing tube with much more diameter. I read it is called "wet well liner"? Is this for better cooling of the teflon liner with water or what is the advantage of this? And a second question: This little silver "knob" between the left trim tab and the stuffing tube, is it an outlet for water which will come into the boat?
Regards BodoComment
IMO, cancel your order on the spartan and pick this up instead! Way better boat for the money.
The wet well stuffing tube isn't for cooling, it just gives you a much wider range of adjustment at the strut. Without it, you can only get a couple degrees of angle adjustment, and no real height adjustment.
I think the silver knob is a water drain, but with it sealed up you shouldn't need to use that much (or ever).Light travels faster than sound, so people may appear to be bright until you hear them speak.Comment
