hey would it be bad to run my boat in like 100 degree weather?
NEW FASTECH!!! :help:
Not if you had a cooler full of frosties. Just keep an eye on motor/esc temp. batts should love it."Look good doin' it"
See the fleetComment
I wish I had the same problem here...... might help the frozen ponds problem"Look good doin' it"
yeah its always like 75 here but in lake havasu in arizona its like 115 and the waters like 65. my dad said it would be fine. he i pretty smart about boats cause we also have a deep vee in real life and they are pretty similar. he might try to make some custom trim tabs for the funtech.Comment
I think you are describing the weakness of the stock hardware. Did you look at my Fastech mods thread? I replaced the stock strut and all those silly linkages with a more traditional strut where you can remove the drive line very easily. I would recommend replacing your hardware with a bearingized strut and .150 cable drive with 3/16" stub. this will solve the majority of your problems you are observing. see rcraceboat.com and Jeff Wohlt has what you need."Look good doin' it"
ok alright.http://www.funrcboats.com/images/pro...PRB3800_md.jpg, the prop should be all the way against the the end of the shaft where it goes through and out of the shaft holder. sorry if this is hard to understand im still a newbComment
