NEW FASTECH!!! :help:
  • p.swiggs
    • 86
    yeah i could. i was just wondering what my options would be.
    • Jesse J
      Former scale FE racer
      • Aug 2008
      • 7198
      I have run 5S, but in parallel... you need to balance out the boat. If you go 1 5S where do you put it? This is what I was trying to explain earlier. Why not try 2S x 2 (4S1P) as Robert says and if you want to go higher voltage, swap out one of the 2S for a 3S (of same mah, c rating and preferably brand), this way you have flexibility. When going higher voltage than 4S/12cells, you should probably prop back to 42mm.
      "Look good doin' it"
      See the fleet
      • p.swiggs
        • 86
        oh ok i got it now. if i did this would i have to change the wiring of anything from series to parallel
        • LiPo Power
          DJI Drone Advanced Pilot
          • May 2009
          • 3186
          ...yes you would, check here for details..
          http://www.offshoreelectrics.com/inf...g-batterie.php
          Canada
          • p.swiggs
            • 86
            yeah i saw that u posted that up top. do u have any pics of what it would look like?
            • Jesse J
              • Aug 2008
              • 7198
              actually the diagrams tell the story. Here's what i did:
              1) take a big pair of diagonal side cutters and clip the battery wires coming out of the ESC about 2"
              2) solder on 5.5 mm bullets (male on the positive and female on the negative - that's my convention)
              3) make a parallel adapter - 2 Y adapters. 1 where two males go to one female and the other where two females go to one male.
              4) plug in the adapters to the ESC and then batteries to the adapters.
              5) give boat a toss and grin big.
              See the fleet
              • p.swiggs
                • 86
                finally got my boat and set it up tonight..YAY!! shipping took for ever. but now i have recieved so much helpful info from you GREAT guys i can strt doing some tweaking. i still wanna run though all stock to see how it is.
                • LiPo Power
                  • May 2009
                  • 3186
                  #23
                  make sure to use good tape to seal your hatch and spent some extra time in corners of it, you need to keep your boat dry inside. Oooo, if your boat will be too heavy front, too wet ride, cut the battery trays such a way that you can move your lipos back a little. That will help in tweeking it.... Lovely boat for sure...
                  We need to see pictures please.....
                  Robert
                  Canada
                  • p.swiggs
                    • 86
                    #24
                    thanks for the heads up. i will be going soon i just need to grease the shaft and ill be ready to go!. I was also wondering where i could get a LIPO programming card?
                    • LiPo Power
                      • May 2009
                      • 3186
                      #25
                      Hi
                      Just post your request under SWAP SHOP for it and I am sure someone will respond to you with it or here:
                      http://www.offshoreelectrics.com/pro...prb3311&cat=75
                      Canada
                      • p.swiggs
                        • 86
                        #26
                        ok thanks..
                        • Jesse J
                          • Aug 2008
                          • 7198
                          #27
                          Hey, I have several and I only need one!! I will ship you one for $15 if interested. they really are the only way to reprogram the ESC
                          Paypal me tonight and it goes out in tomorrows mail - should be there by TGD for sure. PM me and I give you my addy.
                          J
                          See the fleet
                          • p.swiggs
                            • 86
                            #28
                            ok thanks. i will let you know when i have the money for that.most likely in a few days. ill buy it if you still have it.
                            • Jesse J
                              • Aug 2008
                              • 7198
                              #29
                              Your name is written on it and it is waiting. It was just hoping somebody would be looking. Not really something that sells unless somebody wants one. Let me know when you want it.
                              See the fleet
                              • p.swiggs
                                • 86
                                #30
                                ohhhhhhh ok. thanks i will let you know in a couple days.
