Zelos Fast List!!
  • Keagan-Z06
    • Mar 2016
    • 970
    Zelos Fast List!!
    Since both my boats are OTS at the moment, I figured I would compile this for reference. I am pretty sure some info had changed or may be incorrect but this is to start with and I can update as the info comes along. Can members on this list or in the modding thread post their MPH and props here and I update them? I can add a metric for Mods such as motors, esc, etc. For those missing props on this list is because I can't confirm if it was stock or another prop. Let me know and I'll add them. The list is in no particular order unless you guys want me to sort that out by fastest?
    Change (1) Clean up list
    Change (2) Added Mods Section
    Change (3) Added Motor, Batteries, ESC Section (17/11/16)
    Change (4) Sorted by fastest MPH
    Change (5) Who doesn't like a shiny trophy?? The trophy Dino Erickson has is the modded trophy (no longer stock motors or ESCs) The trophy MADRCER holds is the stock configuration trophy (ESCs & Motors remain factory) It is pretty obvious why Dino holds that coveted shiny trophy. I would of loved to get these trophies to the right side of the info for each member but the forum ain't having it.
    Change (6) Must show proof. Either GPS or Data Log
    Change (7) I don't check the fast list daily but I'm pretty active on the forums still. If you want me to add you, post here. If I don't within 2 days, PM me please!
    MODIFIED ZELOS TWIN! (Who needs stock Motors & ESC's?)
    Member: Srtdino
    MPH: 95.9
    Prop: Dasboata ABC 1715
    ESC: Dynamite 160 from (Zelos 48)
    Motors: TP4050 2100kv
    Batteries: 2 x 6s Revo 70C
    Member: Rafael Lopez
    MPH: 93.75
    Prop: ABC 1817
    ESC: Castle 240
    Motor: DYNS1630
    Batteries: Dynamite Reaction 5000 50C 11.1v LiPos x4
    Member: Keagan-Z06
    MPH: 87
    Prop: abc 1915 (47mm)
    ESC: Seaking 180
    Motor: Poseidon 1515
    Batteries: (4)x Revolectrix 3S 4400
    Mods: OSE Flex, Sharpened Rudder, Polish Flex.
    Member: Erroneous
    MPH: 86.4
    Prop: Dasboata ABC1915-17-45
    Mods: Sharpened rudder, Sanded Sponsons, High torque Servo
    ESC: Swordfish 240
    Batteries: (4) 3S Revolectrix 435 silver labels
    Member:paulfromtulsa
    MPH: 78.5
    Prop:X447
    ESC: Turnigy 180
    Motor: TP3605 2080kv
    Battery: (4) 3S Hobbystar 7600mAh
    Member: BanixJ
    MPH: 75.20
    Prop: TFL CNC 4314
    ESC: Stock with timing 7.5
    Motors: Keda Saker SKF-3668 4 poles 2160kv 1650W
    Batteries: 2x Zippy Compact 3300mAh 6s 60C
    Mods: JEFF wire shafts
    STOCK ZELOS TWIN (Factory setup: The way it was delivered!)
    Member: MADRCER
    MPH: 108
    Prop: Dasboata Super Sonic
    ESC: Stock
    Motor: Stock
    Batteries: ??
    Member: MADRCER
    Member: MADRCER
    MPH: 80.77
    MPH: 90
    Prop: ABC 1716-17-45 Dasboata
    Motor: Stock
    Motor: Stock 3831's (Updated factory replacement motors)
    Batteries: 4x3s Gens Ace 5500mAh 45c (11.1v)
    Batteries: 4x3s Gens Ace 5500mah 45c (11.1v)
    Member: srtdino
    MPH: 80.6
    Prop: Dasboata 1715s
    ESC: Stock
    Motor: Stock
    Batteries:3S Revos 5000mah
    Member: GreyBolt99
    MPH: 78.3
    Prop: Stock
    ESC: Stock
    Motor: Stock
    Batteries: 4 x HOOVO 3S 11.1V 5200mAh 100C Lipo Battery
    Mods: None
    Member: Fweasel
    MPH: 77.9
    Prop: Brian Buaas ABC 1715 17-45
    ESC: Stock
    Motor: Stock
    Batteries: Revolectrix Graphene 4x3S 70C 5000mah
    Member: yeeharacing
    MPH: 77.5
    Prop: Doctor Props 640/3 CNC
    ESC: Stock
    Motor: Stock (3831)
    Batteries: (2) 6s Mojo Racing 70-140c 5000 mah
    Mods: wohlt wire drives
    Member: Kfxguy
    MPH: 76.3
    Prop: ABC 1814-17-45
    ESC: Stock
    Motor: Stock
    Batteries: Revolectrix 3S 5500 (Series)
    Mods: Sharpened Rudder, Polished Flex Shafts
    Member: JPriami
    MPH: 75.7
    Prop: ABC1816/3
    Member: Gohan
    MPH: 75
    Prop: ABC 1715 *17-45 (kfxguy prepped)
    ESC: Stock
    Motor: Stock
    Batteries: Revolectrix GoPacks 5000mAh 3s 70C
    Mods: Sharpened rudder, Polished shafts
    Member:Arrover
    MPH: 73.4
    Prop: X447
    Member: Stratus
    MPH: 72
    Prop: ABC 1814
    ESC: Stock
    Motor: Stock
    Batteries: Turnigy Graphenes 65C 6000 x(4)
    Member:DaHammer
    MPH: 72
    Prop: ABC1814
    Member: Chevyprerunner
    MPH:70.4
    Props: Dasbota ABC 1714 17
    Motor: Stock
    ESC: Stock
    Batteries: 2 old Turnigy Nanotech 3300 6s in parallel
    Member: pistol18
    MPH: 70.1
    Prop: Dasboata X447
    ESC: Stock
    Motor: Stock
    Batteries: (4) Lectron Pro 5200, 50c
    Member: BanixJ
    MPH: 69.61
    Prop: TFL CNC 4314
    Mods: Polished JEFF flex shafts
    Member: REDLINE1
    MPH: 69
    Prop: X447's S&B&D
    ESC: Stock
    Motor: Stock
    Batteries: Revolectrix x4
    Mods: Wolt Wire Drives
    Member: Ghandi32
    MPH: 69
    Prop: X447 S&B
    ESC: Stock
    Motor: Stock
    Batteries: Revoelectric Graphene Oxide 5000mah 70c 3cells
    Member: TeamLucas
    MPH: 68
    Prop: X447
    ESC: Stock
    Motor: Stock
    Batteries: SMC 5000 mAh 50C x 4
    Mods: OSE Flex
    Member: vinnyp
    Member: vinnyp
    MPH: 66.8
    MPH: 79
    Prop: ABC 1914
    ESC: Stock
    ESC: Stock
    Motor: Stock
    Motor: Dynamite 3930
    Batteries: SMC 7000mah 90C x4
    Batteries: SMC 7400 3s X (4)
    Member: Keagan-Z06
    MPH: 65.5
    Prop: Dasboata X447
    ESC: Stock
    Motor: Stock
    Batteries: (2) Revos 6S 4400mAh 70C
    Member: Banzee
    MPH: 63.1
    Prop: X447 (S&B)
    Member: Sachaken
    MPH: 63
    Prop:
    Member: mikiek
    MPH: 62
    Prop: CNC 45mm
    ESC: Stock
    Motor: Stock
    Batteries: ??
    Member:mercer2
    MPH: 60.89
    Prop:
    Member: Xtremespeed
    MPH: 58.7
    Prop: Stock (S&B)
  • Keagan-Z06
    • Mar 2016
    • 970
    Well that didn't come out as planned. Will fix tomorrow
      Abc 1814-17-45 props I used
      • Keagan-Z06
        • Mar 2016
        • 970
        Thanks kfx, added!
        • daHammer
          • Apr 2016
          • 23
          Did you do any other adjustments/tweaking to get that figure of 76.3?
            Yes.
            • Xtremespeed
              • Feb 2016
              • 52
              Ran mine for the first time today. All stock. S&B props and sharpened rudder. 58.7mph. Looks like I have a ways to go. Was a little windy though and could only run with the wind. Too much lift the other direction.
              • Banzee
                • Mar 2012
                • 186
                So Keagan , i did a new speed today ! With the x447 S&B !
                • Keagan-Z06
                  • Mar 2016
                  • 970
                  updated!
                  • Banzee
                    • Mar 2012
                    • 186
                    updated!
                    Thank's !
                    • Gahndi32
                      • May 2016
                      • 6
                      got 58mph out of mine box stock. Stock props no prep at all.
                      Sent from my SAMSUNG-SM-G935A using Tapatalk
                      • Gahndi32
                        • May 2016
                        • 6
                        New updated speed on octura x447
                        • Team Lucas
                          • May 2016
                          • 300
                          new speed.. 68.0 stock with de-tongued x447
                          Zelos 36 stock 68 mph
                          • Gahndi32
                            • May 2016
                            • 6
                            updated speed. Stock octura x447. Struts 2mm lower than stock.
                            • Keagan-Z06
                              • Mar 2016
                              • 970
                              updated
