Ok, those of you in the know, please help clear this up:
In the instructions included with the boat AND the PDF found on the ProBoat site it clearly states
"Be sure to use a PRB3311 Programming module to adjust the cutoff voltage when
using Li-Po batteries to protect against over discharging the batteries."
HOWEVER, on the Proboat website, in the "Tech and Spec" section, it states:
Tech Notes
The 60-amp electronic speed control is factory set in Li-Po mode.
Which is it, is it set for LiPo OR is it set for Ni-MH
Do I need to get the programming module just to play it safe?
Tech Notes
