Ni-MH vs. LiPo setting from the factory
  • jfraleyjr
    • Feb 2011
    • 18
    Ok, those of you in the know, please help clear this up:
    In the instructions included with the boat AND the PDF found on the ProBoat site it clearly states
    "Be sure to use a PRB3311 Programming module to adjust the cutoff voltage when
    using Li-Po batteries to protect against over discharging the batteries.
    HOWEVER, on the Proboat website, in the "Tech and Spec" section, it states:
    Tech Notes
    The 60-amp electronic speed control is factory set in Li-Po mode.
    Which is it, is it set for LiPo OR is it set for Ni-MH
    Do I need to get the programming module just to play it safe?
  • jfraleyjr
    • Feb 2011
    • 18
    Anyone?
    Bueller...Bueller...
    • gmkelm
      Noob Stiletto Pilot
      • Sep 2010
      • 10
      I was told by Horizon tech support on the phone that the ESC is programmed from the factory for LiPo's.
      Mark
      • CHIEFY_44
        • Nov 2010
        • 254
        the esc is set for lipo's from factory, but i have the module and used it to make sure it was and to adjust timing, cutoff and throttle settings to linear. But as i stated i already had the programmer from having to set up my MG
        Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180
