One thing I was thinking about on this boat is actually getting rid of the rubber boots, especially around the steering cables, and using teflon tubing inside of aluminum or brass there instead, then running the teflon/nylon tubing the whole length of the cable... More like they do on the VS-1. I think this would give better clearance around the battery cover, and would also look cleaner, and likely be easier to seal. Just haven't gotten around to doing it yet.
Darin E. Jordan - Renton, WA "Self-proclaimed skill-less leader in the hobby."
ron1950 has chosen not to receive private messages or may not be allowed to receive private messages. Therefore you may not send your message to him/her.
If you are trying to send this message to multiple recipients, remove ron1950 from the recipient list and send the message again.
andy, got my new hull today and set it up as best i can without the boots.....heres what the bare hull includes 1) bare hull with decals applied! thats it......i was most disapointed with the fact that it has a drain hole in it but no rubber gasket or drain plug......come on for 138 dollars at least give a guy a water tight hull.....also no battery cover or reciver cover but i did have those from wrecked boat....u know how hard it is to get the old drain plug rubber gasket out without wrecking it? lol.....now i may be all wet here (pun intended) but i would think it could have been a little more generious ...just my 2 cents
I'm not to sure why you guys are finding the boat slow? While mine is not a bullet I had no problems playing with a 40" cat last saturday which runs leopard 40mm power on 4s.
What I have I done to mine?
After it torpedoed a larger gas boat that decided to turn left in front of me I block sanded the bottom of sponsons apart from the repairs that I did.
I got rid of the sheer pin on the drive dog & tapped it, added grub screw & filed a flat spot on the prop shaft...It now has a small amount of play but is much more free. & I am able to now pull the stub apart for maintenance.
I run a grim three blade 40/53
I have set my motor height at 88.5mm (boat set on stand & measure from setup bench to base of cav plate)
Motor angle is set at 12.5mm from center of adjust bolt (bottom for motor trim) to edge of motor mount.
The boat now is a dream to drive & does not hook in the turns.
That sounds almost straight, do you mind posting a picture from the side? Mine is probably not setup correctly then:
95mm for the table to the bottom of the cav plate, measured at the back of the plate
26mm from the motor mount plate to the center of the lower trim bolt.
Which means that it's probably too high and too much positive angle. I do mount both batteries in front, which batts are you using (weight?) and how do you position them?
