Stiletto Race Prep
This is a sticky topic.
  • GP73
    • 544
    #301
    I think Darin indirectly answered your question about the flex shaft, shortening the flex a bit won't hurt, leaving enough space between the coupler and the shaft is fundamental.
    I've ran my Hyperformance stub shaft for a bit now, I haven't used any thread lock on the grub screws, but I'm using smaller grub screws that are flush with the drive dog.
    The tubing goes between your prop and the nut to keep the nut in place and as added security for the prop.
    Originally posted by FastVee
    I just got the Hyper Performance 3.5 Bullet Shaft Assembly and Hyper Performance flex. I made the flat spot on the motor shaft longer and rised the coupler a bit. Is this correct or should I shorten the flex a bit? (dont get why that would even work since the cable wont go any deeper in eighter end...cutting it would only make the square ends shorter and that cant help?) -or am I missing something here?
    Also should the grub screws on the bullet assembly be loctited or not? -greasing the assembly is more difficult if loctited but wont the screws get loose if not glued?
    Is the fuel tubing that comes with the assembly used between prop and nut for smaller props? -or why is that there?
    [ATTACH=CONFIG]55400[/ATTACH]
    Just throwing ideas here, since I have never worked with these ob´s.
    • Just ADD Water
      • Jul 2011
      • 14
      #302
      hello everyone !
      Have had my Stiletto now for a week...lovin it .but the flex shaft broke had to order whole new outboard cause the flaex shaft is on backorder..... Can i have a part number for the lawless flex shaft and Hyperformance stub shaft ...thanx David
      • giddyuperic
        • Jul 2011
        • 59
        #303
        I would like that part # too please.
        • sailr
          • Nov 2007
          • 6927
          #304
          these guys have lawless shafts. Not sure which one fits the Stilletto motor, K&B, O.S., etc?
          Mini Cat Racing USA
          www.minicatracingusa.com
          • FastVee
            • Aug 2008
            • 649
            #305
            Thanks.
            Shortening the flex however wont do anything good. -on my outboard atleast.the problem is that the coupler is too long, if I would cut few mm of the coupler just above the grub screw it would allow more adjustment. If I would just cut the flex(I did try that) it would not help anything cause the flex still wont go any deeper in to the coupler.(it stops going any deeper right at the point the square end changes to round flex).
            For now I just installed washers under the motor mounting screws to raise the motor a bit. After I get the coupler shortened I´ll remove the washers.
            And Darin, the flex on my ob broke half way the square at the stubs end. Thinking the teflon is too small bore( The flex was not easy to rotate inside the teflon by hand ),and the coupler was too high so the shaft was not completely inside the stub.. After that I filed the teflon id a bit bigger so the flex rotated more freely and no more broken shafts. Now I have 7/32 brass tube glued in.
            (needs glue cause I also opened up the holes where the flex exits into the prop-shaft and near the coupler and the brass tube could maybe get through these holes.)
            www.youtube.com/rangerpate
            • sailr
              • Nov 2007
              • 6927
              #306
              The Horizon part number for the Stilletto flexshaft is PRB4033
              Mini Cat Racing USA
              • giddyuperic
                • Jul 2011
                • 59
                #307
                Thanks very much. But I am after the after market fles shaft please?
                • sailr
                  • Nov 2007
                  • 6927
                  #308
                  If you can get an answer from someone regarding which shaft will work, I provided a link above to a third party company that sells shafts!
                  Mini Cat Racing USA
                  • giddyuperic
                    • Jul 2011
                    • 59
                    #309
                    Sorry to keep buging you but how do I know witch one to buy? Or is there one that you cann cut down to work? Thanks for the help newbie here.
                    • CHIEFY_44
                      • Nov 2010
                      • 254
                      #310
                      get intouch with hyperformance and ask them for the cable with the black spiral line down its length i have used this since mine broke and it fits no problem no cutting nothing drop it in and go.
                      there web address:-http://www.hyperprod.bizhosting.com/
                      there phone number:- 714-893-0030 this is also there fax number
                      Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180
                      • giddyuperic
                        • Jul 2011
                        • 59
                        #311
                        Thanks I bought three of them and the guy shop is right down the way from where I live in california. So it worked out great thank you very much. Eric
                        • Rony
                          • Jun 2011
                          • 1
                          #312
                          Just got a new stilello when setting it up with a dx3s i found it has a dead speedy the steering servo works fine.The programming module won,t work with it either has anyone had the same problem.
                          • giddyuperic
                            • Jul 2011
                            • 59
                            #313
                            What do you mean? The program card?
                            • LiPo Power
                              DJI Drone Advanced Pilot
                              • May 2009
                              • 3186
                              #314
                              I am using this one:
                              http://www.offshoreelectrics.com/pro...d=hpi-dc1563s2
                              http://www.offshoreelectrics.com/pro...prod=hpi-psa35
                              The new version of prop shaft assembly should come with screws that are flash with the prop dog. ( Steve has the picture of older original version with sticking out screws )
                              Both in stock! This parts are MUST HAVE if you have few bucks for hardware upgrade on stiletto.
                              Canada
                              • giddyuperic
                                • Jul 2011
                                • 59
                                #315
                                I got a couple of these. When I spoke with the owner he said that these are after market drop in's. Do I need the hard shaft and other part that the other lipo power is is showing us??????
