Stiletto Race Prep
This is a sticky topic.
I have the wobble too, about 2mm in each direction. I never crashed mine, so it could be a wear issue.
I bought a Hyperformance stub shaft here on OSE: it's a drop-in replacement and very well built, but it doesn't turn as freely as the stock one, even after greasing it. I'm hoping it will loosen up a little with usage.
Did you try the M445? How is it?Comment
http://www.offshoreelectrics.com/pro...prod=hpi-psa35
I'd recommend either trimming down the grubs or getting some shorter ones...Darin E. Jordan - Renton, WA
"Self-proclaimed skill-less leader in the hobby."Comment
Has a different transom to prop distance. I think it's tucked up tighter, if I remember correctly. I have one at home, I'll try to look tonight.
Pull the Teflon and do a brass liner like I showed previously. ZERO drag and super easy to maintain.
Better Looking??? I SCOFF at that notion...
I'll try again at some point, I have the entire winter anyway.
And look is subjective, isn't it?
Thanks for a beautiful boat!Comment
Next time you try... heat the brass to an orange glow and then let it cool. That will anneal the metal and it'll bend without any issues. Once you get it shaped, I think you can harden it again. I just annealed mine, bent it to shape, and then put it in. Seems to be holding up great!
Looks are subjective...
But watch for that prop setback. These boats don't always like that to be changed...Darin E. Jordan - Renton, WA
No plans of buying the angle drive for now, but if you get around to check the measurements on your unit that would great!
About the stub shaft: I was surprised to see the grub screws sticking out that much, what would be the reason for that? They run out of shorter ones?Comment
I think, actually, that the longer ones are CHEAPER... I just stuck them on the end of an old allen wrench, and sanded the ends down until they were shorter. Works fine.
Next time you try to do your brass... heat it up, then slide a piece of 1/4" flex (I think that's the right size), down inside the brass before you bend it. On mine, it was a "just fits", fit, and it keeps the tubing from kinking. I just worked it very slowly until I got it where I wanted it.Darin E. Jordan - Renton, WA
I received 2 stilletto outboards today w/o motors. The first thing I noticed is that the prop shafts are very difficult to turn by hand. They should spin pretty easy without a motor attached. So I took one apart and tried spinning the flex shaft by itself inside the teflon. Still difficult to spin! I can see this being very difficult for any brushless motor to spin any prop with this much resistance. I think adding the brass tubing in leu of the teflon is going to be a "must" for the stilletto.Attached FilesLast edited by forescott; 10-26-2010, 06:31 PM.Comment
I also found that my flex cables have a pretty good "kink" where the square end was pressed. This can't help either!Attached FilesComment
