miss geico strut
  • pmark
    • Oct 2012
    • 6
    Originally posted by lenny
    Ok thanks for the info,
    When you go to put the new ones in use lube,
    Should make it a little easier to do.
    Do you have a drill press or a C clamp ?
    Ether one would make it easier to press bushing in for you.
    I have already installed them!
    It was two easy.
    I just slided them in.
    They have a cut from one side to the other so their outer diameter can decrease to slide in place.
    I didnt use loctite! The rotation of the shaft is much smoother now.
    One thing I dont now is their quality and how much I should expect them to last.
    • lenny
      • Sep 2010
      • 4293
      Should be better than the stock ones,
      As long as your props are sharped an balanced good and you lube it.
      I thank you should be set.
      How did it run for you before the strut problem ?
      ? ONLY IF THEY WORK
      • pmark
        • Oct 2012
        • 6
        I bought it second hand and with the flex saft missing.
        I though it would be a good idea to replace the bushings to match the new flex shaft.
        • bob_t
          • Sep 2012
          • 160
          Those bushings look to be the same length. I ordered the Octura bushings and they are a little too long. I had to use bearing set compound on the one we fixed because the one bushing (rear) was worn through, and into the strut. I think a big part of the problem was that the stock PB prop that was on the boat had never been balanced and it was waaaaaaay off balance.
