I bought that rudder for the hell of it. Looks like I'm going to have to file a couple of mm's off where the pin goes thru. Plus it looks like I'll also have to drill the hole bigger for the pin. Not sure on the pin. Just got it in today when I was walking out to go to work. I'll let you know what all was needed to make it work.
Dual water pickup for Miss Geico?
I wish I would have seen this thread before, I just purcahsed this from Kintec because I didnt think the OSE ones would work, but the rudder is gigantic and looks like if wanted it to work would require some heavy modifying.
5 Inch Rudder Short Base w/ Dual Water Pickup CNC machined aluminum rudder and mounting bracket with dual water pickups and servo arm. Brass bolt for kickback protection.
5 inch (128mm) from bottom of mounting bracket to rudder tip.
1 1/2 inch (38mm) from transom to leading edge of rudder.
Transom foot print is 1.7" (43.4mm) wide and 1.26" (32mm) high.
Rudder width tapers from 1 1/4 inch to 1.1
Servo arm w/ 2mm swivel. All stainless steel locknuts, bolts and washers included.Comment
