Dual water pickup for Miss Geico?
  • Jason4636
    • Jun 2012
    • 654
    Originally posted by srislash
    Looks like that Spartan rudder should work for you Jason.Not cheap though.
    If you look at this thread you can see it should be easily adaptable.http://forums.offshoreelectrics.com/...-Submarine!-X3!
    I bought that rudder for the hell of it. Looks like I'm going to have to file a couple of mm's off where the pin goes thru. Plus it looks like I'll also have to drill the hole bigger for the pin. Not sure on the pin. Just got it in today when I was walking out to go to work. I'll let you know what all was needed to make it work.
    • Jeremy
      • Jun 2013
      • 24
      And?
      Thinking of buying that same rudder for the Impulse 31 (V2).
      It's either that or getting the dual rudder conversion kit to get a second water line.
      • ray schrauwen
        • 9471
        RC Boat Bitz sells a dual intake rudder blade that just bolts on to the Chinese Pursuit hull/rudder mount... 130mm or 160mm long but, not as wide as above...
        EBAY----
        Nortavlag Bulc
        • smittyj77
          • Sep 2012
          • 89
          I wish I would have seen this thread before, I just purcahsed this from Kintec because I didnt think the OSE ones would work, but the rudder is gigantic and looks like if wanted it to work would require some heavy modifying.
          5 Inch Rudder Short Base w/ Dual Water Pickup CNC machined aluminum rudder and mounting bracket with dual water pickups and servo arm. Brass bolt for kickback protection.
          5 inch (128mm) from bottom of mounting bracket to rudder tip.
          1 1/2 inch (38mm) from transom to leading edge of rudder.
          Transom foot print is 1.7" (43.4mm) wide and 1.26" (32mm) high.
          Rudder width tapers from 1 1/4 inch to 1.1
          Servo arm w/ 2mm swivel. All stainless steel locknuts, bolts and washers included.
            • 7673
            Do not run the brass break away bolt. You will rip the transom right off.It pulled the the through bolts right out of my 11lb Komodo and the brass bolt did not let go. Change to plastic and good to go.
            • silversurfer
              • Dec 2011
              • 11
              big motor for that hull
