Little Twin G
  • HYDROJERRY
    • Jan 2010
    • 2503
    #106
    To busy with work!!!! i dont no i think i hear a sniffle in your typing maybe you need to take a sick day and work on boats,,,,
    • Make-a-Wake
      FE Rules!
      • 5557
      #107
      How did boring out the slots work on the collet?
        • 7673
        #108
        Worked great Carl.Now if I can just find a 23 spline long servo horn for my Speky servo I'll be happy. Integy has some but no one local so far.Oh and I need to put foam and lead in the nose.
        • mtbenjamin77
          • 761
          #109
          Reverse your prop
          rotation and you'll loose the hop
            • 7673
            #110
            Originally posted by mtbenjamin77
            Reverse your prop
            Guess I should try that before doing anything too radical.
            • lenny
              • Sep 2010
              • 4293
              #111
              Now why didn't you think of that.
              That help a lot with that twin mono from Finland.
              FastVee, I think.
              ? ONLY IF THEY WORK
                • 7673
                #112
                That help a lot with that twin mono from greese.
                Coolmines I think.
                Only the fourth run coming.It takes time to work this stuff out.Nearest water is 1/2 hour drive away. Props spinning inwards means dual rooster tails,I like that.
                • lenny
                  • Sep 2010
                  • 4293
                  #113
                  Hear you go something from the past.
                  ? ONLY IF THEY WORK
                    • 7673
                    #114
                    So what powers that beast Len?
                    • lenny
                      • Sep 2010
                      • 4293
                      #115
                      I think they were T600 880kv outrunners,
                      Link to build.http://forums.offshoreelectrics.com/...e-style-build)
                      I know he had a problem with a esc or motor at one point.
                      Also was not running good till he reversed the rotation and that did the trick.
                      ? ONLY IF THEY WORK
                        • 7673
                        #116
                        I found in the Shocker that spinning outwards was all the difference.So that is what I did with this one.I'm playing at the race course tommorrow so I'll mess with it then.But for now going to put foam in today and I have the stingers set down a bit.
                        • HYDROJERRY
                          • Jan 2010
                          • 2503
                          #117
                          Yes please put some foam or something inthere, heck i was thinking of putting some in my rc drift car just cuz im so used to it,hahaha
                            • 7673
                            #118
                            I got some foam in there Jerry.And an inflatable rescue dingy today.I found the Twin can do other tricks too.
                            So I am off this week so I will try the props the opposing direction next,and get better vid.Sorry guys.
                            • HYDROJERRY
                              • Jan 2010
                              • 2503
                              #119
                              Well it looks like it cruzes pritty nicely shawn, and runs upside down hehehe, i have a blowup raft also and hate using it so i only try to run in the summer time so if anything happens i rather just swim for mine, i use diver fins so its not so tireing when i get to the boat!!! Last time i used my brothers fishing rod took afew tries but i got it hooked and pulled her in..
                                • 7673
                                #120
                                The raft will be good for the race course spot as others will be there as well.I have thought of using my rod,it is in the van, just haven't figured anything out for the end.
                                I think I may mulch up the lead that I have in there and epoxy it into the bow tips.Hopefully I can decrease the amount of lead this way.
