Esc keeps coming de-soldered
  • lenny
    • Sep 2010
    • 4293
    Hey,
    Do you have any pictures of the boat and hardware on it inside and out ?
    Is the 42x55 props sharped and balanced ?
    And what make is the 50c cells ?
    ? ONLY IF THEY WORK
    • yfzbrad
      • Jun 2012
      • 34
      [QUOTE=lenny;441690]Hey,
      And what make is the 50c cells ?[/QUOTE,,
      I can put some pics up later when I get back home.... but the packs are gens ace... and all the connectors are castle creations 5.5 bullets stock motor and esc
      • yfzbrad
        • Jun 2012
        • 34
        And yes the prop is sharpen and balanced.
        • yfzbrad
          • Jun 2012
          • 34
          I moved the strut up and ran it with 30c packs and I ran the whole packs down to cut off... no melting... 50c packs connector melts off. I maintain my boat to a t. All connectors are tight. And like I said all the other temps are right around 100. I just ordered a seaking 120 so we will see what happens. Thank you everyone foe your input. It just seems like the esc should go first before the connectors.
          • lenny
            • Sep 2010
            • 4293
            Ok that will help,
            On a two minute run what are the temps at the 5.5 bullets at all connectors ?
            Can you try the 50c packs in something else ?
            Are they 50c hard packs ?
            ? ONLY IF THEY WORK
            • ray schrauwen
              • 9471
              How much difference in weight are the 50C from the 30C?
              If they are heavier, putting them further back may help a little. The weight may increase amp draw. Check your radio to see if it is at full 100% end point?
              Just diggin' .
              Nortavlag Bulc
              • ray schrauwen
                • 9471
                I think maybe the smaller esc wires are choking off current??
                Nortavlag Bulc
