Esc keeps coming de-soldered
  • yfzbrad
    • Jun 2012
    • 34
    Anybody have any input on why the red wire on my esc keeps melting the solder on the connection at the battery? I know I did a good job soldering the connector on. It is the stock proboat 45amp esc and I have 5.5mm bullets on everything... Running 5000mah 50c 2s packs with a grim 42x55. This is very frustrating. I run about 3 minutes and done. Time to go swimming. all other temps are right around 100.
  • yfzbrad
    • Jun 2012
    • 34
    Sorry... I am using 60/40 tin to lead solder.
    • Heaving Earth
      Banned
      • Jun 2012
      • 1877
      Try adjusting your strut. Where is it at now?
      • yfzbrad
        • Jun 2012
        • 34
        I was told to set the boat on a level surface and set up the strut parallel to the hull. So that's where it is at now.
        • Heaving Earth
          Banned
          • Jun 2012
          • 1877
          Try raising it up 3/16 above the bottom of sponsons
          • Heaving Earth
            Banned
            • Jun 2012
            • 1877
            Also, You should make sure esc wires are same length as eachother. Same goes for battery wires. Ex. You don't want red and black wires from esc to be different lengths
            • yfzbrad
              • Jun 2012
              • 34
              I am willing to try anything... All the wires are the same length. Just out of curiosity what effect does the little changes on the strut have on the wires? Just so I can wrap my head around what i am doing.
              • dana
                Banned
                • Mar 2010
                • 3573
                having the prop buried can cause the motor to have to work harder = wires and plugs heat up quick.
                you dont want the motor to work so hard to move that prop. having it raised will obviously ease up the load the prop is putting on the motor, and will in turn cause less heat on the connectors and wires.
                • MORIDE
                  • 102
                  It is hard to say, obviously you are getting hot, have you resoldered it many times? You might try soldering it directly and see what happens.
                  Sent from my Nexus 7 using Tapatalk 2
                  • yfzbrad
                    • Jun 2012
                    • 34
                    Its not the esc to motor wires... its the battery to sec wire...ran again yesterday 30c batteries fine... 50c bullet came in soldered again. 5.5 should be able to handle it so I am lost.
                    • yfzbrad
                      • Jun 2012
                      • 34
                      Stupid phone... esc not sec... sorry.
                      • roadrashracing
                        • 1462
                        try propping down and see what happens
                        • MORIDE
                          • 102
                          Well throwing out random thoughts, try propping down but you should not be having that prop on stock 4S setup. Have you tried diff 5.5 bullets? Are you bullets a tight fit? Is the drive system free no binding? Strut set even with pads? Shaft/Cable greased well? They do make larger bullets. Are you settings correct for the PB ESC? Do you have the program card? Have you moved the motor, if so make sure collet isnt hitting bracket. Water running thru the cooling system well? Is it always the same 50C battery or has it done it with several diff ones?
                          • roadrashracing
                            • 1462
                            my 4s setup gets hot with that prop to when I had it.
                            • dana
                              Banned
                              • Mar 2010
                              • 3573
                              Did you move strut up? Also shorten your runtime. Real simple
