Hopped up Miss Geico Stutters
  • Ripper
    • 65
    I have a Miss Geico with a leopard 4082-2200 on 5s with a T-180 Seaking and an M645 GPS'd right at 60 mph but it stutters from the time I put it in the water. I'm running the original Spektrum TX and RX with a reciever pack. Is it just pulling too many amps or is it a loss of signal issue. Any suggestions are greatly appreciated, I'm kind of at a loss. I think I hear a beep from the esc when it stutters but not really sure.
  • jamespl
    • 742
    What batteries are you using mah and c rating? I would imagine the 4082 is an amp hog. I'm looking at getting 4082 2000kv on 4s in my genesis and will be using 2x2s 5900mah 60c packs.
    • LOVE6S
      • May 2012
      • 521
      How many runs on the lipos and do you know what stuff is running temp wise?
      • LOVE6S
        • May 2012
        • 521
        How many runs on the lipos and do you know what stuff is running temp wise? I really like the paint did you do it?
        • LOVE6S
          • May 2012
          • 521
          How many runs on the lipos and do you know what stuff is running temp wise? I really like the paint did you do it? Try shutting the low volt cutoff off and try it.
          • Ripper
            • 65
            I'm using a 2s -5000 mah and a 3s -5000 mah Turnigys 35c. I have a couple of sets of these and they've been good for the last 18-24months but I agree that the 4082 is an amp hog. I guess I'll get some 60c batteries. On the last run the esc was about 120° the batteries about 115° and the motor 130° so things are running pretty hot.
            I'll also turn off the LVC and just check the time.
            Thanks for the compliment on the paint, I did it myself last winter with rattle cans of automotive paint from AutoZone.
            • LOVE6S
              • May 2012
              • 521
              Those temps dont seem that bad, try lowering or shutting off the low volt cut off and time your run, do a short run, the t180's can be funky all of a sudden with the cut off kicking in.
