"that" miss geico
    • 7673
    #196
    Looks good to me.Who ended up doing it for you?
    • masonis1
      If you cant control it 👍👍
      • 1173
      #197
      This guy named jon. Hes a good guy
      Sent from my SPH-D700 using Tapatalk 2
      • masonis1
        • 1173
        #198
        Just tested the boat... Last night i programmed. Wrong... I had to put it back to zero lipo cutoff. It was at halfthrottle for the firstvtest. Fadt but not... Took it home. Turned cutoff off and tested. Holy cow. Like a bat outta hell. Fast. Turns and plans better with the blueprinted.hull. The prop grabs on fast. It hooks up. A lot less cav starting off. Fast and tons of torque. Love the motor swap. After 2 minutes the motor was at 120 ans esc at 93. motor has no cooling on it motor was still cool to touch. It was a hot and windy.day. Still ran good. About 95 today and i took the.temp.of the esc and motor before i.ran. Motor at 91 and esc at 90. it was sittkng on the porch for a while at ny grandparents. Im running 15* on motor. Ran great. Cant wait until i get a day about 85 and hardly any wind.
        • masonis1
          • 1173
          #199
          So... Been thinking. What makes electric.motors in.general spin faster or slower. How do.they change the.kv of a motor. Seems like most the rotors i see in brushed look the same yet some motors spin much.faster. Brushless i.dont know. Please explain.
            • 7673
            #200
            It has to do with the way the copper wire is wound,how many winds and the magnet size.In a brushed motor the rotor has the windings and in a brushless the can has the windings and the magnets turn.
            • masonis1
              • 1173
              #201
              So the amount of windings changes the.speed
                • 7673
                #202
                Yeah,Has to do with the current and resistance.Same as the brushed motors: 55 turn,35 turn,27 turn,right down to 6 or 7 turn.A 55 turn has alot of torque and less rpm whereas a 11 turn is good for a race buggy.
                • masonis1
                  • 1173
                  #203
                  Yep. I have a 55 in my crawler and a 19 in my cup racer.
                  • masonis1
                    • 1173
                    #204
                    Well.found a new home for the ul1 motor. Putting in my venom creeper crawler to make a foff truck. Shouls.be a.interesting.build. Tips?
                    • masonis1
                      • 1173
                      #205
                      im going to try and get a octura x642 today for the boat. maybe even.see if i can.get a cooling jack for the cc.
                      • masonis1
                        • 1173
                        #206
                        of course my.hobby store didnt have the x642 but they did.have checkered.flag tag.
                        last part of painting this.beast!..
                        now i.need.help on how to lay this. need help
                          • 7673
                          #207
                          What do you mean "help to lay this"?Bear in mind I have a BBQ to go to.
                          • masonis1
                            • 1173
                            #208
                            i dont even have a boat within 40 minutes of me. so nbd. have fun
                            i meant i need help figuring.out how to.lay it down straight all around and prevent a lip on the bottom of the hull
                              • 7673
                              #209
                              What kind of decal is it?Just a normal vinyl decal?You may be able to moisten it with soapy water and then you can slide it around on the boat till you are happy.Then squegee the water out and let it dry.I have someone I can ask if you like.
                              • masonis1
                                • 1173
                                #210
                                ok please ask. just normal vynal i think
