Mod Time
  • BoyZie
    I believe I can fly
    • Feb 2012
    • 22
    Mod Time
    After receiving my MG some time ago and running it on 2s 50 5000nmh I decided it was time to hot it up a bit. I spent quite a bit of time looking through the MG forums at what people have done and the problems they have had. In order to fix the weak factory join that joins the top deck and bottom hull. I decided cut the hull apart and removed the balsa wood and bog from the join as this is the weak spot. I laid two layers one chopped mesh one cross mesh the full length. I did the same across the front and back too and now the join is supper strong.
    I also decided to relocate water outlet to the back left top side. The second step was to fix the riding pads as they had dips and a slight curve, so it was time to blue print the riding pads and sharpen up the edges at the same time. I am now at the painting stage. I still have too glass in motor mount and Carbon Fiber Battery Tray.
    • 7651
    Nice job Boyzie,Are you doing anything with the transom/strut bracket?Those blind nuts are weak.
    • BoyZie
      I believe I can fly
      • Feb 2012
      • 22
      At this point I am leaving it stock, but have carbon fiber back plate with s/s nuts to go if needed.
      • jasoncyclone
        • Jun 2011
        • 475
        Looks pretty good! What kind of power are you going to use?
        Miss Geico CC1515 2200kv T180 2S2S- Twin Genesis with 2 2700kv 2 T180's 4S2P- Stiletto with 2030kv T120 4S1P-DF33 4082 1600kv T180 6S2P- and lots of gassers!
        • Make-a-Wake
          FE Rules!
          • 5554
          Nice build............
          • BoyZie
            I believe I can fly
            • Feb 2012
            • 22
            I have decided a 4074-combo leopard 4074/2000 & seaking 180 combo on 4s2p.
              • 7651
              That is a nice combo there.
              • Make-a-Wake
                FE Rules!
                • 5554
                Sounds like an x645 may be in order for some super speed!!
                  • 7651
                  Or better yet a M645.That is my latest favorite on my MG.
                  • BoyZie
                    I believe I can fly
                    • Feb 2012
                    • 22
                    Yet another rainy Saturday stuck in doors and unable to mount motor as the Heavy duty water cooled mount for Leopard 4074 / 4082 is for a v hull. The motor is about 10mm past bottom of mount. So will have to make mount extension at work or use some aluminum box cut to fit. I spent some time today looking at making decals on cheap transparent film to see what it would like here are some pic.
                    • BoyZie
                      I believe I can fly
                      • Feb 2012
                      • 22
                      Should the mount for Leopard 4074 / 4082 using a leopard 4074/2000 fit MG, as the motor sits past the bottom of the mount??IMG_1075.JPGIMG_1074.JPG
                        • 7651
                        I had to make my own CF rails for my 1515.It had to be higher 13mm I think.Geez,I never think I'll have to make another one.Why didn't I write that down.Do you have some CF or FG plate?
                        • BoyZie
                          I believe I can fly
                          • Feb 2012
                          • 22
                          No I don't have any, I will have to find out where i can buy some in OZ.
                            • 7651
                            If you have no luck ask Nata2run
                            • BoyZie
                              I believe I can fly
                              • Feb 2012
                              • 22
                              Found some at Hobby-king in OZ and and ordered some https://www.hobbyking.com/hobbyking/...MM_Thick_.html
