Your MG that started off as a hull
With the advent of Zenoah's new 20cc engine, I think now the Komodo can run using gas power!
I read of one early user who adopted it in his 33" boat! It looks to be the perfect gas power plant for 35"-40" boat hulls.
If FE BL motors are going for the bigger gas hulls - now gas engines could go for smaller FE hulls!Attached FilesComment
My Aquacraft SV27's old Video: http://www.youtube.com/watch?v=VoTm4Btz41Q
MHZ Micro Iceberg, Skunksworks Gen2 Cat twin, Aquacraft SV27, SM29 1515 sold.Comment
Shawn already has a Twin BL powered Komodo. I saw another one being built with a single BL motor. I hope there will be a Komodo with a Zenoah G200pum. Hehehe!My Aquacraft SV27's old Video: http://www.youtube.com/watch?v=VoTm4Btz41Q
Weird thou - i emailed Gizmo and asked when he'll be getting his stocks of the new Zen g20s, then he replied and said he wont be carrying it. Yikes!Comment
If only Gizmo will carry the G200 it will be a little more affordable. Hmmmm I wonder if our buddy Johnny can get this one?lols!My Aquacraft SV27's old Video: http://www.youtube.com/watch?v=VoTm4Btz41Q
It does open up new options in our hobby!Comment
Hey Mac,
Is this what I need for my pipe ?
However, please check the distance of the header from engine to 90 degree bend. You might need something that is longer.
Here's what you do:
- place your motor without any exhaust system in the middle between the 2 wooden railings.
- with your detached tune pipe, lay it down on the left side interior of the boat
- the fattest portion of your tune pipe is called a "belly" - when it is layed down on the left side along the wooden railing, tape it down on the boat (or shim it with something) to have 1/4"-1/2" gap between belly and wooden railing. This is because if the belly is too close the wooden railing - it will melt the lip of your radio box. The radio box's lip rests on top of the wooden railing, so if the belly of your tune pipe is touching it - it will melt the radio box.
- when the tune pipe is laid down with the proper gap - measure from the front pipe to the engine. That is the length you would need for the header before it bends the 90 degree.
I hope my explanation above is clear, but will attach 2 pics below for you to see what Im talking about.Attached FilesComment
I for got that this is what Joe had in this thing.
Hey Mac,
Today I modded the pipe by cold bending it out a little bet.
I think it looks pretty good now,
It's just all laying in the rails and motor not mounted yet,
Not to sure on the CG yet.
But the motor is setting in between the old mounting holes of the twin motor setup in the last pictures,
I think it should be ok like this, Just may need a pipe hanger or stop added some where on it.
Also was thinking of putting the gas tank I have in the bulk head hole in front of the motor,
I need to open that hole up anyway to fix the bow right, And reinforce it the best I can.
big gas cat 009.jpgbig gas cat 011.jpgbig gas cat 010.jpgComment
[ATTACH=CONFIG]92569[/ATTACH][ATTACH=CONFIG]92570[/ATTACH]
Hey Mac,
[ATTACH=CONFIG]92571[/ATTACH][ATTACH=CONFIG]92572[/ATTACH][ATTACH=CONFIG]92573[/ATTACH]
All good info and learning experience!Comment
Thanks,That cool.
It worked out good than.
Gas cat 4.jpg[/ATTACH]big gas cat 002.jpgbig gas cat 009.jpgComment
Yup, there are various shapes of headers depending on your application - there's the typical "L" shape that comes in 90, 100 and 105 degrees, the "deep vee" headers like yours, "wrap to center" and even "wrap to front".
The purpose of the bends is to provide the ample distance that the exhaust gas needs to travel in relation to the type of tune pipe based on the physical allowable space inside a hull. You cant just slap a tune pipe to a header and be done with it as a properly tuned exhaust will provide you the max potential power of your motor while an improperly setup exhaust will rob you of it.
A modified engine would always be more critical to tune than a stock engine would. Over here, we try to keep the 13"-13.5" distance measured from engine exhaust port to the middle of the "belly" of the tune pipe. For stock, start with probably 14"-15".
Measurement should be made in middle of the pipe - so as a guide, cut a string to your preferred length gently placing it on top of the header and leading towards the belly of the tune pipe. The end of the measured string should end exactly on the belly of tune pipe.Comment
