Best setup ?
  • CHIEFY_44
    • Nov 2010
    • 254
    I use 60/40 solder I get it from fry's not sure of the name but its on a spool with purple sticker on it, when I get home I will get the name for you
    Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180
    • Brushless01
      • Apr 2010
      • 487
      Also any setup tips sorry for the questions never owned a cat before.
      Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
      • gek1946
        • Jan 2011
        • 95
        Run Times
        Originally posted by CHIEFY_44
        Imo I wouldn't run 6s I have read threads where they run 5s but I am a 4s runner in the MG I run 4s2p with a leo 4074 2200kv as with my insane FE30 sport rig and getting good run times
        what kind of run times can i expect with a 4074/2000kv with a m445
        using 7.4 5500mah/35c 2s Traxass batterys in a Geico. Will the times be better
        on series or paralell?
        • CHIEFY_44
          • Nov 2010
          • 254
          Not very long lucky to hit 5 mins, I run 4s2p 4000mha which gives you 8000 mha when in par, and 14.8 volts, in series this setup would give me 4000mha and 28+ volts, if you have 2 packs 4s exactly the same use them in par, longer run times.
          • TheShaughnessy
            • 1431
            Stock motor will take 6 s. I ran mine with a 40 x 55 and a t 120. I only made a few passes though, not sure I would recommend it for sport running. @ offsetting the rudder does nothing... Is that a joke? Do you own a mg? Speculation from reading is not experience and you should act like you know. My rudder offset cost about 3 bucks and worth every penny. Offset may not get rid of the wha wha but it is a handling improvement.
