Best setup ?
  • Brushless01
    • Apr 2010
    • 487
    Best setup ?
    Hi huys picking up my missG on Thursday and was just looking around trying to find the best cog/strut and rudder settings ? Also are there any mods that are reccomended ? I already have a m445 and a x440/3.
    Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
  • jasoncyclone
    • Jun 2011
    • 475
    I read the Miss Geico Sticky and about everyother thread I could find to find all my answers. There is so much info in this section. One of the first mods I did was blueprint the sponsons.
    Miss Geico CC1515 2200kv T180 2S2S- Twin Genesis with 2 2700kv 2 T180's 4S2P- Stiletto with 2030kv T120 4S1P-DF33 4082 1600kv T180 6S2P- and lots of gassers!
    • CHIEFY_44
      • Nov 2010
      • 254
      Another mod is offsetting the rudder, also m445 with bottom of strut level with bottom of sponsons is a good starting point
      Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180
      • JackBlack26
        • May 2007
        • 905
        Again, offsetting the rudder has not been proven to do anything to this hull. Save your money and spend it elsewhere.
        • T.S.Davis
          • 6221
          Based on what? What does "proven" mean? Not sure it "proves" anything but my Geico is 11 laps ahead of my nearest competitor on the season. I'm ahead of an H&M No Step 3 mono that handles like it's on rails.
          Offset the rudder. It absolutely does help. That's why the Mystic comes with the rudder offset from the factory.
          Noisy person
          • CHIEFY_44
            • Nov 2010
            • 254
            I agree with ts davis, it helped with my MG but the best thing u can do is blue print the hull, also take your time with cell placement and strut height, another thing which is a must is putting foam into the sponsons helps stop the hull from splitting after a hard crash, and get one of tiquemens hatch's as the standard one sucks.
            But really just follow darin's prep thread, you won't be dissapointed.
            • Brushless01
              • Apr 2010
              • 487
              Ok thanks guys already got the carbon and am going to reinforce the hull and hatch and get a carbon servo mount and rip out all that horrible wood ! As far as blue printing the sponsons whats involved in doing this ?
              • JackBlack26
                • May 2007
                • 905
                Based on the fact that Darin Jordan made mention of this on other threads. Look for it on this forum. The Mystic came with an offset rudder to eliminate prop wash. Also many members who have made the modification have mentioned that it does nothing for the boat, as most people try and get rid of the "wha, wha" this way. It may make for better turning towards the right and eliminate the prop wash on the rudder if you are racing, but for average recreational usage it makes no difference. There have been plenty of before and after tests. Everyone agrees to not see a difference, from what I have read.
                Not looking to start a pissing match. Just stating what other have reported.
                • CHIEFY_44
                  • Nov 2010
                  • 254
                  Blue printing consists of making sure you don't have any concaved area's on the sponson ride pad bottom's use bondo to level these out, while you are doing this make sure all the ride pads touch your setup board or flat surface because if say the middle ride pad is not touching when the other 2 are this will make it porpoise, also make sure the sponsons are square along the inside and out side edges, square off any rounded corners, pay attention to the rear of the ride pads nice sharp edges does make a difference. Its a pain in the butt but well worth the effort imo. Mine still has a tiny bit of wahwah but I am still playing with cell placement and things.
                  Hope this helps you, but darin explains it in detail in his race prep thread.
                  • Brushless01
                    • Apr 2010
                    • 487
                    Thanks guys anyone ran 6s on here with the stock motor with a T180 ?
                    • T.S.Davis
                      • 6221
                      For average recreational boating why do anything to it?
                      We most know different everyones.
                      Noisy person
                      • CHIEFY_44
                        • Nov 2010
                        • 254
                        Imo I wouldn't run 6s I have read threads where they run 5s but I am a 4s runner in the MG I run 4s2p with a leo 4074 2200kv as with my insane FE30 sport rig and getting good run times
                        • ksaucerman
                          • 86
                          Chiefy 44 what kind of battery connectors do you use with the 4074 2200kv t-180 4s2p set up? My ec5 connectors always melt the solder out with this same exact setup using a m445 prop.
                          • CHIEFY_44
                            • Nov 2010
                            • 254
                            I use 5.5mm connectors, make my own Y connections with similar connectors, I must be very lucky as I have not had any solder joints melt anywhere, I do reconmend using a good iron I run mine at 700 deg and also use flux on every joint, this way works for me.
                            • ksaucerman
                              • 86
                              Thanks going to change to the 5.5 was going to try the novak 3% silver solder what do you suggest for solder?
