Loosing prop power
  • TheBoatbojo
    • 22
    Loosing prop power
    My Geico is loosing prop power when I push in the throttle control. It will start for a second and then stop, however if I tweek it carefully and get some rpm on the motor, it will work fine until I let out the throttle again and the same problem occurs if I push it in to quickly again. Anyone having this problem and have a solution?
  • Skholar
    • 29
    What are your ESC settings? Sounds like you're hitting the LVC......
    • TheBoatbojo
      • 22
      I have not done anything with the ESC, so factory setting, and the bats are fully charged (2x2s 4000mha Turnigy). The ESC does not beep when I turn it on either btw.
