Well took the boat out for the second time and still did not get to drive it. I plug in the lipos and wait for the control to connect and nothing but steering...... then out of the blue full throttle....... then before I can get the control off pop goes the end of the shaft with the prop... Wtf??????? What do you think is the problem.........
geico gone mad
what type of radio do you use?, but sounds like the rx and tx are not bound together, i sometimes get the same thing with my dx3 i have got into a routine now i change models and go back to the main screen then switch off the tx a couple times and that stops it other than that i don't have a clueSocal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180 -
try plugging in your batts turn on the controller, switch on the boat power switch, when it beeps, if no beeps adjust the throttle nob on your controller untill the motor beeps,,then pull the trigger and it should run slow then its set ,, it wont spin up high untill its in the water with load on it,,, if it runs backwards swithc any 2 of the motor wires!!!!Comment
Did you calibrate the throttle when you installed the turnigy?Comment
Sure did ot was working perfectly the first time, but the next it just went little haywire. Have not used it since Tue prop blew off but should have everything together tomorrow and returned it and c what happens. I have not drove it more then 6 minutes total............ man I hope ot works fine tomorrow.Comment
