geico gone mad
  • tman
    • Jun 2011
    • 113
    geico gone mad
    Well took the boat out for the second time and still did not get to drive it. I plug in the lipos and wait for the control to connect and nothing but steering...... then out of the blue full throttle....... then before I can get the control off pop goes the end of the shaft with the prop... Wtf??????? What do you think is the problem.........
  • CHIEFY_44
    • Nov 2010
    • 254
    what type of radio do you use?, but sounds like the rx and tx are not bound together, i sometimes get the same thing with my dx3 i have got into a routine now i change models and go back to the main screen then switch off the tx a couple times and that stops it other than that i don't have a clue
    Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180
    • tman
      • Jun 2011
      • 113
      I have the 2.4 spectrum
      • dana
        Banned
        • Mar 2010
        • 3570
        It's a proboat. There's your problem. Damn electronics in those things fellate cattle
        • HYDROJERRY
          • Jan 2010
          • 2503
          try plugging in your batts turn on the controller, switch on the boat power switch, when it beeps, if no beeps adjust the throttle nob on your controller untill the motor beeps,,then pull the trigger and it should run slow then its set ,, it wont spin up high untill its in the water with load on it,,, if it runs backwards swithc any 2 of the motor wires!!!!
          • tman
            • Jun 2011
            • 113
            I don't have a on/off switch anymore. I have a castle 2200 and a turnigy esc so the on off switch is gone...
            • tiqueman
              • Jul 2009
              • 5669
              Did you calibrate the throttle when you installed the turnigy?
              • tman
                • Jun 2011
                • 113
                Sure did ot was working perfectly the first time, but the next it just went little haywire. Have not used it since Tue prop blew off but should have everything together tomorrow and returned it and c what happens. I have not drove it more then 6 minutes total............ man I hope ot works fine tomorrow.
