Still thinking about final paint but this is the progression.
Repaint after repair
Tags: None
Good start! Check out what a few accents items can do.
http://forums.offshoreelectrics.com/...ad.php?t=24505
Oh, and if you haven't already, reinforcing the canopy is a MUST. -
Cosmetics
Pulling most of my supplies from the professionals around me. Cool stickers though. Just trying to stay inside the lines on such a small scale....:) I used Awlgrip with a reducer and a metal flake.Attached Files" You can tell how fast it is by how many flips it does on the blow over"Comment
Seems that replacing the magnets with quick turn fasteners would be a good choice? Thinking of adding a third one in front and filling the factor "pin" mount, thoughts?" You can tell how fast it is by how many flips it does on the blow over"Comment
I installed the rear kintec quick locks for the hatch and for some reason they are very hard to get to lock seems like they should be a couple mm longer but its a great ideawashed up factory racers edge driver.. past LHS owner now im back to the hobby I love
I have ordered the Kintec fasteners. I had planned to bed their height with epoxy/fiber. Am I in for surprise?" You can tell how fast it is by how many flips it does on the blow over"Comment
I am confused. Did you set your lid level and shim/dry fit the base prior to installing the base peice? If so, what went wrong?" You can tell how fast it is by how many flips it does on the blow over"Comment
i put 1 quick latch on mine but i bought 2 and used the nut off the second to adjust the height so it fit correctlySocal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180Comment
just a little fyi on the hatch pins I ran up to ace hardwere and the nut in the lamp repair section is the same nut as what comes with the pins I used it to adjust height up now works perfect kintec might want to include a extra nut since they wont work with out itwashed up factory racers edge driver.. past LHS owner now im back to the hobby I love
