Hull Truing
  • wppracing
    • 109
    Hull Truing
    Decided to true the hull and all the imperfections are visible. The process didnt take long at all to do. The red areas are the low spots. The pictures are from start to finish. Hope to run it later this week.
    Watercraft Performance & ATV
    wppracing.com
  • JackBlack26
    • May 2007
    • 905
    I'm doing this to mine during it's rebuild.
    Now scuff up the paint so it doesn't stick to the water like a flat piece of glass.
    • JPriami
      N4FOX
      • 1675
      Back edges of the sponsons still looks a little rounded. Should be sharp and crisp. Maybe they are and its hard to see from pics? The leveling looks good.
      • wppracing
        • 109
        Still waiting on the paint to dry and then some fine tuning. This is so much easier to do than the jet skis we have done for racing.
        wppracing.com
        • ron1950
          • 3024
          What did u use to fill with?
          • boaterkid333
            • Dec 2010
            • 25
            what is the benefit of doing this?
            • martin
              • 2887
              The hull runs smoother & faster.
              • boaterkid333
                • Dec 2010
                • 25
                can you tell me what materials you used and instructions on how to do this, i want to know what im doing so i dont mess up my sponsons
                • JPriami
                  N4FOX
                  • 1675
                  Some reading for you here.
                  Start here at post #43
                  • martin
                    • 2887
                    You want sharper edges along the sides & rear of steps + a srubbed finish rather than a shinny finish. But will still run better than before you filled the hollows. Martin.
                    • wppracing
                      • 109
                      Finished the fine tuning on the hull and hope to test the boat later today.
                      wppracing.com
                      • boaterkid333
                        • Dec 2010
                        • 25
                        can i use anything other then filler? filler is 40 bucks for a pint and not worth it
                        • toyotatruckin
                          • Aug 2007
                          • 110
                          Hope thats not spot glazing putty -- if it is take some lacquer thinner on a rag and remove it, it shrinks and is not durable, finishing putty like tec-flow, 3m's piranha putty etc is best to use on thin or shallow areas deeper areas body filler like bondo, and thicker areas dayna-glass< very hard to work with use it to rough it in and finishing putty to feather and fill the low spots, spot glaze is more for pin holes
                          • wppracing
                            • 109
                            The sponsons were blocked sanded to show the low spots. Then they were sanded with 220 grit, Bondo was applied to fill in the low spots. Then blocked sanded again. Any low spots were filled again with bondo, sanded again. Then spot putty was used to fill in and air bubble marks etc. Then the sponsons were final sanded with 400 grit. Hull was whiped down for painting with a tac cloth, sealer primer way applied, and final white coating was applied, about 10 light coats. Allowed to dry and the edges sharpened and scuffed.
                            wppracing.com
                            • boaterkid333
                              • Dec 2010
                              • 25
                              Will these products work? The autozone store is walking distance from my house.
                              Filler and Primer
                              http://www.autozone.com/autozone/acc...er=167018_0_0_
                              http://www.autozone.com/autozone/acc...er=468793_0_0_
                              And paint over it with any color spray paint also?
