Stock ESC burned up
  • highfly24
    • Jan 2011
    • 16
    Stock ESC burned up
    Hey everyone, I was running my MG yesterday when it just stopped working. I charged batteried to make sure I didn't have a bad battery, blah blah blah the usual check over stuff. I took it out, and it was definitely burned. Smells like a burnt esc does. Anyone else have any problems? I am going to send it off and get a new one I hope, because it is still under warranty. I will probably put a different one in, but what is a good replacement ESC?
  • Diesel6401
    Memento Vivere
    • 4204
    What batts where you using?
    What prop?
    Stock motor?
    * Seaking 120
    * Hifei Swordfish 120
    * Seaking 180
    * Hifei Swordfish 200
    - Diesel's Youtube
    - Diesel's Fleet
    • LiPo Power
      DJI Drone Advanced Pilot
      • May 2009
      • 3186
      If you did not change any from stock it will be replaced.
      What was your set up?
      Canada
      • highfly24
        • Jan 2011
        • 16
        Stock motor, and two 7.2 or 7.4v hard-case 5000 mAh lipos. stock prop, nothing was changed.
        • Diesel6401
          Memento Vivere
          • 4204
          * Any binding in the drive shaft & proper direction flex cable?
          * Properly lubed shaft?
          * Gap between the drive dog and the strut?
          * Any half throttle or less then full throttle running the majority of the run?
          * Any excessive turning/hard constant turning where the boat would be on/off plan often?
          Any/All of those could lead to esc failure.
          - Diesel's Youtube
          - Diesel's Fleet
          • highfly24
            • Jan 2011
            • 16
            well, i mean i have to turn it, but not excessively, and no binding, the boat was running fine the last 3 of 4 runs, and everything was how it should be.
            • Diesel6401
              Memento Vivere
              • 4204
              Yea I hope your turning lol. What I mean by excessive turning is a lot of new guys like to make super tight turns like trying to make the boat do a donut or tight figure 8 or something and it's just horrible for the esc.
              You may be the 1 out of 100 that got a bad one. Horizon should cover it no problem, there customer service is awesome!
              - Diesel's Youtube
              - Diesel's Fleet
              • highfly24
                • Jan 2011
                • 16
                Yeah, I've dealt with their C.S. before, we fly planes, and we have bad stuff here and there, and they take care of it no problem! Thanks Diesel!
                • JimClark
                  • 5907
                  How long did you run it for?
                  Billy Graham
                    • 9488
                    I think Horizon will send you a new one if you call them...
                    • highfly24
                      • Jan 2011
                      • 16
                      Yeah, I'll give them a call tomorrow, and I've never had a problem with them.
                      and Jim, I would run it until it started driving really slow, but I had the ESC programmed with slow cut-off, lipo, and I had greased the flexshaft. It was probably time to re-grease it, but it was running just fine and then cut out. I'll send it to them.
                      • LiPo Power
                        • May 2009
                        • 3186
                        Did you use programming card to swich your esc to lipo from NMH as this is set up for them as defoult?
                        Canada
                        • pyroM!KE
                          • Jan 2011
                          • 375
                          If you get a new esc from HH sell it and get a SK180..Especially if you plan on 5s running.. If you decide to keep the new esc and you dont have a programmer I have a stock esc programmer for sale..
                            • 9488
                            how is this done by the way?
                            you can run 5s on the stock esc
                            • Diesel6401
                              Memento Vivere
                              • 4204
                              It's easy with the card. http://www.horizonhobby.com/ProdInfo...ing_Module.pdf
                              Also set the motor timing to "HIGH" with the stock motor and make sure throttle curve is "LINEAR"
                              Yup you can run 5s. I been doing it for a while. Dis-able the bec and run a rx pack and change all the bullets over to 5.5mm or higher (stock 3.5mm & deans won't handle it)
                              - Diesel's Youtube
                              - Diesel's Fleet
