Ok so I received my 4074 the other day from ose. The one on the site is red can but the one they sent me is a black can. Not sure if there is a difference but as I'm about to install it I notice the shaft is about 1/4 inch longer and its not a direct fit. Has anyone else had this problem and I would asume the only way to fix it is to cut it down to size which I'm not to happy about
leopard 4074 shaft cutting
I'm not sure why you would be "unhappy about it" since different manufacturers have different specs for their motors. Why should Leopard have the same shaft length as ProBoat? The Leopard site has the motor dimensions, did you check it before you ordered the 4074? Not trying to be a smart a$$ but this is a normal thing to do when changing motor brands.
Bottom line - if the Leopard shaft is too long, cut it off with a Dremel or similar tool. When cutting, place the motor in a baggie with just the shaft sticking through to keep cuttings out of the windings and magnets.
Cutting the shaft is very common...especially if you ever want to run thrust bearings. Put the motor in a bag and pop the shaft through then cut it off with a dremmel. Smooth the shaft edge and make your new flat spot.Comment
Ok just thought maybe that's why it was longer because of different color can not the first shaft I've cut just haven't really heard of anyone having to do it.. I have all the tools so I guess I got my answer thanks for the helpmiss gieco cc 1518 62.1mph [/COLOR][/B] Delta Force 33" cc 1717Comment
Try not to over heat the shaft as you cut it.
If you have a cup of water nearby, you can dip the hot shaft in water to cool it as you go.
If it sizzles when you dip it in water, you are getting it too hot.Nortavlag Bulc
keep us advised on the mg after u try out that 4074 in it.....that is if it doesent go into orbit on the first run.......btw how many cells u planning to run it on?MY RETIREMENT PLAN?????.....POWERBALL
74 vintage kirby clasic hydro, pursuit mono, mg, 47'' mono, popeye hydro...Comment
