Picked up a new Miss Geico today, also bought a few extra goodies to make her go fast. I'll be using a Neu 1515 1.5y 1500kv motor, X2-Thunder Power G4 45c Pro 5s pack's (3250mah), Octura x447, Castle Hydra 240, Octura Coupler and a few extra's. I would really like to break 70mph. I will post video's next week when everything arrive's.
70MPH PB Geico
That's why I opted to the 240 and bigger prop, not to mention I had only 25c lipo's.... 6s May be a tight fit. I'm guessing the 447 will get me mid 60's easy. Just my opinion.LMT
LehnerMotorenTechnik.comComment
Would it be dangerous to run the 1.5y on 6s and a octura x646? I'd like more than just 30 second run time's and this setup run pretty hot...
Maybe 5s on the 646?LMT
I think "Fluid" has a formula that sounds real close...
5S will get you a shallow 50 with a 447, 6S will get you to 60...
Try 6S with a 642 and see if she don't run nice, I think the 646 might load it too heavy...
Keep us posted...Comment
Just started to run her on 5S. Did a 2:30 min run on x645, everything came back cool. On my second run the solder joining the flexdrive and prop shaft gave out (no other damange). Once I fix the shaft I'll plan to run longer on x642 and back to x645 if still coming in cool. I really liked the speed on that config with x645 and handling was manageable.
I've read some threads where 6S could be pushing the hydra 240 controller.
ChiefComment
i ran a 1515 1.5y on 6s2p with a x646 all day everyday who ever says you cant has no idea about rc boat or is giving bad advice in a h@m drifter you will get 98 kph on 6s2p and on 1p 92 kph if you run it on 5s in the mg being smaller you should get 95 kph i also ran a 1521 1y on 6s2p and 1p with the same prop 2p was 113 and 1p was 101 hope this helpsComment
