Miss Geico-What Works For Me
  • hobie
    • 98
    #46
    You guys... if you noticed in my mod that I posted when this first came up, you should move the rudder FORWARD as well as to the side. I try to line up the leading edge with the drive-dog or front of prop, which keeps the rudder blade clear of the thrust cone... I drilled new holes in the rudder assembly to accommodate moving it forward as well...
    That being said... mine is currently back further than that, and it doesn't have any porpoising at all when the balance is set correctly...
    I have a question about all this offset stuff. Mine still bounces even with the offset rudder, when I'm using a 642, when I step up to a (or down, depending on how you see it) to a 447, runs smooth as glass. The question, can the rudder be to close to the transom?? I was thinkin of getting a whole different rudder assmembly, so the the offset rudder and the drive are 2 separate pieces. I just don't want to order the wrong part, by having it to close to the transom.
    The rudder I was thinking of is this one, or similar.
    http://www.offshoreelectrics.com/pro...ros-rud-dualpu
    • ron1950
      • 3024
      #47
      does it lose speed with the 447 at all? if not id just use that one but i am cheep and dont want to pay 50 bucks for a new rudder lol good luck with it
      • Jeff Wohlt
        • Jan 2008
        • 2716
        #48
        I think it is the rudder design...not about it being inline. Other cats do not have this problem with inline rudders. My hor cat runs great with that set up.
        I may try another rudder and see if that helps before I mount it over to the side.
        www.rcraceboat.com
        [email protected]
        • hobie
          • 98
          #49
          Ron, I'm only trying the smaller one cause when I'm using the 447, the wires get really hot after only a few min of running. The 447 also pushed the boat to 45 mph on 5s, with 642 I'm only getting 38?? I was told it should be faster with the 642. Doesn't seem to be the case. But the wires are way cooler running the smaller prop.
          I'm going to move the rudder in and over a bit before I drill any holes.
          See if it runs smooth with what I did today. I'm using the octura offsets, so I just drilled two new holes on the rudder clamp, moved it right up as far as I could. And put a small spacer in to move it away from the prop a bit.
          I will test it tomorrow and let you know. As long as the snow stays away...
          • ron1950
            • 3024
            #50
            some will disagree but i found mine likes smaller props with some pitch also...dont know why but it stays cooler also.....bummer about the snow....i though we had it bad cause it finally rained today lol
            • tman52804
              • Apr 2009
              • 101
              #51
              Airman,
              I just installed my seaking 180 amp esc and the motor wires really make it difficult to get the inner seal and canopy on. Did you quit using the inner (smoke colored) cover/seal?
              • hobie
                • 98
                #52
                Lol! You must be way down south. I'm in Vegas today for a course, looking at all the water makes me wish I brought a boat with me!!!! Going home tonight to about 1.5' of snow, and I'm pretty sure the ponds are now solid!!! I'm jealous of you southern boys!!! It's 75 degrees out!! No snow, and I'm wishing I wasn't way up in the north.
                I wasn't able to test my new setup, now, if I could find a pool or something. Lol!
                Guess I have to wait till spring, or come back south very soon.
                • ron1950
                  • 3024
                  #53
                  with any luck your basement will flood and u can test it out then...lol...actually all that snow makes u guys appricate the summer more then down here......it was 68 today and i thought it was too cold to go to the lake.....
                  • blackcat26
                    High Speed Junkie
                    • Sep 2009
                    • 1598
                    #54
                    I'm keeping the inline rudder.......I just moved my motors away from the rudder!
                    FE BOATING: Less like a hobby and more like an addiction!
                    • tiqueman
                      • Jul 2009
                      • 5669
                      #55
                      Offset shafts.... BRILLIANT!
                      • ron1950
                        • 3024
                        #56
                        nice..........
                        • Boomer
                          • 285
                          #57
                          Blackcat26
                          How about some more pictures? Like whats under the canopy? It was just a matter of time before someone did this. Very, very nice. This boat was born to be a twin.
                          Boomer
                          • blackcat26
                            High Speed Junkie
                            • Sep 2009
                            • 1598
                            #58
                            I'm sorry to the OP for this is a partial hi-jack. I simply posted that pic for humor.....Boomer check me out in the boat building section for all the details.
                            • jac4412
                              FE Addict
                              • Jun 2010
                              • 425
                              #59
                              Yeah I'll ateast to the Kinetc's bracket strength... I was using an industrial grinder and the thing was actually slowing down when I was wearing down the bracket... and heating up the metal till it began to get soft. Very strong aluminum. So I took of the bottom part (the red shown in the 3d image) but left a small section to maintain the 2 screw hole. I'm undecided if I want to take off the blue part yet... since It will be accelerating on a straight line most of the time that part shouldn't cause drag (just a negligible amount). But if I find that it is a problem in my turning I will take it off.
                              JAC4412 RC
                              • tiqueman
                                • Jul 2009
                                • 5669
                                #60
                                Prop/ gps tests
                                Ran a pack w/ my niehbors BJ26 this am. If it wasnt for corners, his BJ definitely would smoke the MG. Im not havin that. Listening to the two boats run, same proboat motors, same batteries, his BJ winds out way more than the MG. I had a GPS in her and she came in at a dissapointing 33.4mph. This was using Turningy 5000mah 40-50C packs. So he left and I began some testing. I removed the x642 that is S/B/DT&C'd and installed a S&B x640. I installed the same rated packs that were peaked a week ago and came in w/ 35.5mph. Progress. The boat seemed to want to bounce a bit more with it. Perhaps I needed to move the strut up a bit. However, instead, I puled it and installed a m445. She threw up a lot more water in the roost, couldnt tell at first as it was going away from me if it was better or worse. Strangely, I heard no "wah wah wah". I turned her around and ran towards the shore. She was gettin it, tru as could be and definitely the best shes run. GPS showed 40.4! The only other change I made in the boat was last night I installed a T-120 ESC in the event I ran 5S today. For two reasons, 1.) Even though some get away w/ it, I will never run a PB ESC on 5S again as I smoked one doing so about a year ago. 2.) Seeing "Yoda's" amp results , I did not want to run a 445 on that esc. Im sure it would be fine, but I need to test to see if I can turn the 445 for 4 minutes for Offshore. Im sure the PB esc would came in a bit warm after that. I hope it works out, if not, seems the 640 so far is the way to go.
