There has been a ton of information listed here on OSE regarding Proboat's Miss Geico. I wanted to take the time to show what I have done with my set up so that other Miss Geico owners might be able to gain some possible insight. To preface things a bit, I am a sport user, not a racer. I love speed, but not at the price of small scale nuclear explosions. Reliability and enjoyment are of paramount importance when it comes to my FE rigs. Out of the box, Proboat's Miss Geico is a fantastic boat in terms of build quality, performance and ease of operability. Having said that, some things are left to be desired. Namely, the porpoising. By trial and error, I have found that the porpoising is caused by the stock in-line rudder configuration and nothing else. I tried multiple props, COG adjustments, battery placement and what I found was that an offset rudder configuration eliminates the porpoising 100%. I ordered the Kintec Racing offset bracket and it works, except that it introduces a significant amount of drag which I found to be unacceptable. I ended up altering the Kintec design by removing the bottom portion of the bracket as shown in the photo below. This kept the bracket out of the water line and eliminated the drag. I also installed an aftermarket rudder which is 4" in length versus the stock 3.5" rudder. This change brough back the amazing handling that was somewhat lost when I originally offset the rudder in the first place. The next modification I did was to remove the stock power system. Now don't get wrong, the stock PB 1500 motor and ESC are damn near invinceable at 4S but I wanted more speed without having to tweak the heck out of the stock components. This means I didn't want to blueprint the hull. After consulting with Steve at OSE, I chose the Leopard 4074 2000kV motor and Hobbywing Seaking 180 V2 ESC. This duo, combined with a S/B/P Octura x642 prop nets me speeds in the mid-fifties every run. The temps are luke warm at most and that is considering the fact that I have 5.5mm bullet connectors on everything. I am also not using the BEC and have opted to use a 1600mAH NiMH Rx pack instead. My batteries are (2) Zippy Flightmax 5000mAH 2S 40C packs for a total system power of 4S (14.8v). Based on past perfomance baselines, I decided to stick with my trusty Tactic 2.4GHZ Tx/Rx combo because I loathe antennae's. Differrent strokes for different folks there. This system set-up lets me run in the mid-fifties reliably and safely every time I go out and I always come back with a huge smile on my face because I didn't sink the boat or cause any explosions. Thank you to all of you who have posted here because you have given me a lot of valuable information and further enhanced my love of this incredible pastime!
