Bad Kitty! Stop bouncing!!!
  • igottalongone
    Banned
    • 204
    I see alot written about the MG "bouncing" most times it's just a set-up issue...
    Take your hull, loaded with packs. canopy, etc, etc and see where your CG is... Your "sweet spot" is 9" forward from the transom. That's 9" from the back of the boat, not the hardware. If your boat balances, your stylin, my guess is it ain't even close! I had to build up longer battery trays, almost to the transom to move my packs back.. Once you get it to balance, make sure the top of your strut is flat, level and flush with the top of the mount, same with the rudder. See how it run's, if your bouncing play with the strut angle, but,, do not give the stut positive angle to force the nose down, this will cause bouncing! Do just the opposite, lift the nose a little and air your kitty out... The hull wants to fly, thats what they do best... Once she's running good wide open (close... but not too close to blowing over), you can do tiny adjustments with weight, TINY adjustments...
    C-Ya at the Lake!
    Ron
  • Doby
    KANADA RULES!
    • 7280
    Sweet running boat, What prop?
    Grand River Marine Modellers
    • igottalongone
      Banned
      • 204
      running a X642 in this vid, and not taxing motor at all. The esc will need to go away to see top speeds from these boats, I'm getting spikes over twice the rated amprage. I'm gonna run her till it pops
      • AndyKunz
        • Sep 2008
        • 1437
        Ask Darin how far above the rating he has run the ESC...
        Proboat does the same thing I did with my RC-Hydros.com ESCs for years. Under-rate them so that if anybody ever blows one up, you can be pretty sure they were WAY over the top.
        Andy
        Spektrum Development Team
        • igottalongone
          Banned
          • 204
          yo Andy, are you the guy who built the RCHydro controlers?
          • AndyKunz
            • Sep 2008
            • 1437
            Yup.
            Andy
              • 9488
              Nice looking run
              • blackcat26
                High Speed Junkie
                • Sep 2009
                • 1598
                Ron, welcome to the Forum my friend. Thank you for posting your results to help us out. Batteries back, opposite of what everyone else was suggesting.
                • Darin Jordan
                  • 8335
                  Yup... Thanks for posting these results guys. This is the opposite of what worked on the sample boat, but it didn't have the concavity on the ride pads, so I'll be interested in watching to see how the setups go for those who are blueprinting the bottoms.
                  ALMOST have the perfect RTR package here... just need to see if we can get the manufacturer to do something about getting the ride pads to cure true.
                  Keep up the great setup threads, guys... this is fun.
                  Darin E. Jordan - Renton, WA
                  • blackcat26
                    High Speed Junkie
                    • Sep 2009
                    • 1598
                    Darin the paint is dry and should have some runs on her today. Can't wait to see what flat pads do!
                    • Darin Jordan
                      • 8335
                      Hopefully, it makes it BETTER, not worse!!
                      • blackcat26
                        High Speed Junkie
                        • Sep 2009
                        • 1598
                        Yeah really. Surely it will be better. I was cringing the whole time sanding down the beautiful yellow/green on her.
                        • Darin Jordan
                          • 8335
                          I know... but they are ride pads... if anyone is looking at those... your setup still isn't correct!
                          • jac4412
                            FE Addict
                            • Jun 2010
                            • 425
                            igot did you run it on the stock prop? I'm curious what the esc rating is under that, running an x642 shouldnt change it that much....
                            JAC4412 RC
                            • Diesel6401
                              Memento Vivere
                              • 4204
                              Thanks for adding your findings Ron.
                              - Diesel's Youtube
                              - Diesel's Fleet
