Bad Kitty! Stop bouncing!!!
  • Boomer
    • 285
    #46
    Servo mounting brackets - cowl locks
    Dale
    I just ordered some aluminum servo mounting brackets/frames, and some aluminum push locking type cowl locks. I originally thought of these for my Genesis, because it has no latching devise built into it, but thought hey, if the magnets on the Miss G didn't hold in flip, it wouldn't be good, so I ordered them for both boats.
    I think I saw the cowl locks on one of the guys Genesis on a Youtube video. I started a search for them and found them both on E-bay.
    Boomer
    • Diesel6401
      Memento Vivere
      • 4204
      #47
      Originally posted by ron1950
      Did you make new trays or just move your old ones I thought I'd use some floatation material to fit the battery into and leave the trays in place. Not sure yet. What everyone else doing ?
      I left the original trays in place and made extenders that butt up against the stock ones and just made them a little longer and the I tacked them in place with ca glue in all 4 corners with a shot of ca accelerator then I used some 2 part epoxy on them to keep them in place for a long time. Came out pretty good I think.
      - Diesel's Youtube
      - Diesel's Fleet
      • Diesel6401
        Memento Vivere
        • 4204
        #48
        Originally posted by Boomer
        Dale
        Boomer
        Yea i've seen those cowl locks on a few boats they look cool as hell. That servo mount looks bada$$ as well.
        - Diesel's Youtube
        - Diesel's Fleet
        • scoota
          FE DOWN UNDER
          • Dec 2008
          • 409
          #49
          With some prop testing on miss-g , i found running a M445 prop took the bounce out of the hull with the batteries in there standard position .... I should add im running a 1515/1y cc/neu
          UL1- 1515 castle/neu / 240 swordfish
          SV27- with UL1 running gear
          33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
          • ron1950
            • 3024
            #50
            thanks scoota now i have to put out another 50 bucks for a worked over m445 lol
            • scoota
              FE DOWN UNDER
              • Dec 2008
              • 409
              #51
              Or you could sit for hours on end working / sharpening & balancing a 14 buck M445 like i do LOL
              • ron1950
                • 3024
                #52
                naa ill let you spend countless hours working/ sharpening and balancing a m445 for me lol
                • ron1950
                  • 3024
                  #53
                  just ran the mg for the first time....wow.....seems much faster then the stiletto but may just be the excitment talking......haD stilletto prop on it......i had the bateries about 2/3 of the way back in the trays but didnt lower the strut...just wanted a base line to go from.....hoped like a bunnie lol but was really fun to run on glass water.....at about 2/3 throttle......did the 5 min lowering of the strut and got the rudder back stright( looks as if i tapped something with rudder)...ready for the next run tomorrow if i can get up that early...retirement is tough i tell ya!
                  • Diesel6401
                    Memento Vivere
                    • 4204
                    #54
                    Ok some more pics. You can see the telemetry heat sensor wrapped around the caps on the esc. I choose the esc over the motor although I could quickly move the heat sensor over to the motor if I chose. I tried to wire 2 heat sensors into the 1 telemetry port using a "y" harness but that didn't work to good. The temp jumped up about 30 degrees with both hooked up then when I would disconnect 1 it would red room temperature. It was worth a shot I guess. Here's the issue I had with the super short antenna on the sr3300t rx, 2" out of the hull is the highest I could get it. I hope it's enough. Radio check was good for about 20yds.
                    - Diesel's Youtube
                    - Diesel's Fleet
                    • tman52804
                      • Apr 2009
                      • 101
                      #55
                      What did you do to waterproof that RX?
                      • jac4412
                        FE Addict
                        • Jun 2010
                        • 425
                        #56
                        I thought darin said the rx was already waterproofed
                        JAC4412 RC
                        • tman52804
                          • Apr 2009
                          • 101
                          #57
                          No, not the telementry receiver that diesel put in his boat.
                          • Darin Jordan
                            • 8335
                            #58
                            Only the MR-series are "water resistant"... The SR series aren't...
                            Darin E. Jordan - Renton, WA
                            • Diesel6401
                              Memento Vivere
                              • 4204
                              #59
                              I use this stuff, it has saved a tactic rx and a esc:
                              - Diesel's Youtube
                              - Diesel's Fleet
                              • Diesel6401
                                Memento Vivere
                                • 4204
                                #60
                                Hey Darin you think my rx antenna is out of the hull far enough? You know how short the antenna on the sr's are.
                                - Diesel's Youtube
                                - Diesel's Fleet
