Prop question for Blackjack 26
  • koontek
    • Aug 2007
    • 167
    Hey guys,
    I have a blackjack 26 that has been modded up. I am running a ammo motor with a hextronic ecu both are being water cooled. The hardware has also been upgraded to a inline setup. My question is i am running a grim racer 36x55 1/8th shaft prop on 14 cells and the boat is a monster! but its running way too hot. this is after doing a couple of passes and bringing it in to double check on everything. I would say about 3-5 mins of run time. I'm not very good at choosing out props and was wondering what you guys think a step down would be to make my motor run cooler? any input would help me out. Thanks!
  • bigpapa
    • Apr 2009
    • 2330
    octura x642
    • Meniscus
      Refuse the box exists!
      • Jul 2008
      • 3222
      What kv is the Ammo and what battery setup are you using? 4s1p?
      • koontek
        • Aug 2007
        • 167
        Originally posted by bigpapa
        octura x642
        hey, i didnt see the x642 in a 1/8th shaft. only the x632 it looks like.
        • koontek
          • Aug 2007
          • 167
          to tell you the truth i'm not sure what kv the motor is. I bought it sort of the way it is and there is a water jacket on it. I'm running 14 3600 nimh cells. should i try the x632 guys?
          • Steven Vaccaro
            • 8724
            Most people use a brass sleeve to use the x642 on the bj26 3mm shaft.
            Like this
            http://www.offshoreelectrics.com/pro...?prod=ose-1035
            Or simply make one.
            I would not jump to the x642. Its much more pitch than your current prop. The x632 is a bit smaller than what you have, but may experience cavitation problems because of the reduced diameter. You could also try reducing the diameter of your current prop a bit.
            Steven Vaccaro
